rebuild 4g63
kaninbu
669
104
1,543
hi,need some opinion from u guys...
im driving an airtrek wif evo4 engine.lately engine bay seem running quite hot than normal(can feel the heat more).new set cooling system from alluminium radiator,fan controller,low temp termostat has been installed.problem is running water temp normal 80c-85c.izit head gasket pecah?since my evo4 almost 10 years n clock around 140k milleage.izzit time to rebuild?how much does it cost?:confused::confused:
thanks....
ehdrian
I Don't Care!
3,310
280
1,683
Penang
day time water temp is quite normal between 85-90deg..
calvin9683
1,768
171
3,163
JB
Running temp seems normal... My E7 oso around 85deg when driving around or cruising on highway... If idling wif aircond on, same reading... But if idling without aircond, temp goes up to almost 95deg then only fan start running...
Basically not much diff for stock radiator n aluminum radiator... Just changed to AVS radiator coz my stock ones had a bit of leaking issues...
kaninbu
669
104
1,543
yes,my airtrek is na convert e4.e4 has better internal compare to airtrek e7(detune).temp running normal but engine bay very hot leh
ehdrian
I Don't Care!
3,310
280
1,683
Penang
bro, turbo engine is hotter than NA, maybe u r not used to it..
kaninbu
669
104
1,543
bro,even my mechanic also complain mine engine bay is hotter compare others normal airtrek turbo.izit head gasket pecah or td05 is hotter compare td04??
kaninbu
669
104
1,543
at 1st wana get 1 de but even ori turbo hood water also can sip in the engine plug n cause missfire.lotsa airtrek member oso kena.when they switch fmic.
ehdrian
I Don't Care!
3,310
280
1,683
Penang
hmm, but water temp seems normal..:confused:
calvin9683
1,768
171
3,163
JB
as long as water temp is ok... aircond is cold...
i dun see if there's any problem lo...
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
Engine bay for sure hot ma.....zzzzz
If head gasket problem...ur water temp edi above 100c lo
Since u r using low temp thermo wit fan controller....u can set the fan to kick in earlier to match the low temp thermo
i've decided to put the LMST saga side skirt and LMSS(Iswara SE) front skirt for my iswara sedan..but i had a problem with the back..
OR is there any type of bodykit that can fit into iswara
opinion/ideas/suggestion..
got pic,emel me at [email protected]
need help from ya all..!!!!
thanks
