Rear camber arm help
Poacher
85
18
508
Auckland, NZ
Hi Guys,
My Rear camber arm (LH rear lower) which has the camber adjustment and the bottom of the shock goes onto it is screwed, bolts seized need to be cut off.
Is there any other car that has the same type of arm i can take? Airtrek parts are hard to come by i am hoping evo 7 is the same (i am told it is not) or evo 3??
Also looking for an evo 9 bypass (BOV) valve second hand if anyone has anything,
Thanks!
Since this section goes more general, I decided to move my thread here. Here it goes:
Due to my old-aging SOHC non-vtec engine, what occured is that one end of the crankshaft which connects to the pulley broke...... got towed to a workshop, but the tauke said that have to change crankshaft, crankshaft bearings and also most of the seals since my engine is also leaking oil quite severely (gote quoted RM1300 overall). My question is, I understand on the seals part, as since they are already...
