rad fan not stopping
slipar
500
61
banting - pj
hi all neo owner..
my friend car got some issue..
car is neo 1.6 auto with no mod..
got some issue about the cooling system..
is it normal for the fan to run non stop when engine reach operating temp..
before reach operating temp fan not running..
but after reach operating temp fan run non stop..
if on air cond before reach operating temp fan run n stop but after reach operating temp fan non stop run..
is it normal or maybe the cooling got some issue..
change thermostat n water temp sensor alr..
thanx in advance..
slipar
500
61
banting - pj
but the fan run non stop after reach operating temp..
no interval what so ever..just run non stop..until key switch off then the fan stop..
slipar
500
61
banting - pj
weird for me also..
not many friend use campro engine so ask here loh..
no choice but to go pdt for now..
hope nothing serious..
sam8888
18
1,503
kuantan
my neo had the same problem also...after i switch off da key,the rad fan wont stop it...after 5 or 10 minutes just stop it...whats the problem??
slipar
500
61
banting - pj
done pdt..no prob on all sensor..
but the pomen that done pdt remove thermostat then fan normal..
that pomen said no thermostat better..wtf !!!..
now temporary running without thermostat..
pic attach show temp after driving about 4km..
* sorry for the blur attached pic
xtremeleo
3,247
464
5,183
dont run it witout a thermostat, the fan not switching off right after the engine has stopped operating is normal, most contis are like this iirc. if its not turning off langsung, then there wud be a problem. iam suspecting a faulty temperature sensor, or a faulty thermostat. for ur case, get a new thermostat
slipar, has your friend tried a complete ECU reset? Ie- take out the battery terminals and leave overnight and then plug it in the next day?
Ok,found this article about how to make twin muffler/exhaust system that is consist of s-flow and straight flow at the same time.
but the problem is i dont know where to find the parts and if i can use another part that is same like it.
For an instance, the valve.
Automatic Dual Mode Muffler = loud when u want it loud - MallCrawlin.com Forums
i hope you guys can make it into Malaysian's version.hehe
