Question about spring rate
cheehong
99
Malacca
any body know what mean this numbers " 250/40" or "250/30" that print on the spring?
how to calculate/convert it in the kg/mm unit?
thanks....
PutraCraze
273
this might be like this... 250 stand for length, 40 stand for spring rate.. might be 250mm in length and 4.0kg in spring rate... this is already in kg/mm unit.. if u put 4kg then the length would to shorten 1mm... if i'm not mistaken.... du a test on the spring c wat i say is correct or not...
mahfudz_mn
181
21
Bukit Jalil
yup...ur rite...250/40 and 250/30 is length/spring rate
length is in mm while spring rate is in kg per centimetre...
btw...r u using rg? wira/satria? the figure sounds familiar
azir
62
which one could consider more stiff? 250/40 or 250/30?
cheehong
99
Malacca
im using RG...on my satria SE..
feel that it is not hard enough laa....
thinking want to change the spring to 5f4r...any one try b4?
mahfudz_mn
181
21
Bukit Jalil
wow...buddy...ur body made of impact absorbing foam kah? jk, anyway i used that b4...can even push it down...i drive satria 1.6, i think that its stiff enuff adi...wuts more the rg suspension they dont really tune the damping rate good enuff...cant set the ride very low...macam naik kuda...hahaha...i think it should be okay if u change to 5/4, but prepare urself to the meaningless talking of the rg marketing man...to him...any probs...its ur car not my suspension
cheehong
99
Malacca
my RG i brought from a zth member....
can any body tell me where is the location of the RG factory?
RG is local made or local assembly ?i see my spring had printed with "RG Germany" wo..
thanks..
PutraCraze
273
klang... ask jinkl to bring u there... if u r using SE satria stock standard engine... pls.... stick to the setting now... is the best... still can travel on penang stage road if u came down to penang... if u change it.. don't come.... AT ALL... used 6kg front 4kg rear... in my car... front is ok... back of ur car pls dun go further then 3kg... if i were u.. i will revalve the shock especially the front...
Scared of thief break in if yes its time to get some personal device to protect ya self.
Selling:electric stun gun for rm77 include postage good enough to know a man down size like a hp
