do these things work?PPF usually stands for Paint Protection film....
No:4 Spar Urethane he bought whole tin. Actually is for wood finish.....Sorry I meant no.4.
Use hard coating type la. 1 year with that much maintenance is really short. I never bothered with my Myvi when Kenneth and it lasted 5! Well, it wasn't completely clear and went a bit yellowish but didn't blur up.I used duragloss nano glass coat. I bought it for my car paint actually but well heck why not try it on headlamp also. On car body it lasted for around 10 months (with spray wax topping every week) then the roof coating gave way first then followed by the hood and side mirrors then the doors. Coating on fender and door lasted for almost a year
Hard coating is expensive....one small bottle cost around RM300-400 ...FYI Cv is my first name, kit is my last name. And my middle name is Miskin. Cv-miskin-kitUse hard coating type la. 1 year with that much maintenance is really short. I never bothered with my Myvi when Kenneth and it lasted 5! Well, it wasn't completely clear and went a bit yellowish but didn't blur up.
:hmmmm: dont know if i can believe that.....Hard coating is expensive....one small bottle cost around RM300-400 ...FYI Cv is my first name, kit is my last name. And my middle name is Miskin. Cv-miskin-kit
Oh those clear coat for wood to make it shiny and water resistant is it? Those that you normally apply to wood using a brush?No:4 Spar Urethane he bought whole tin. Actually is for wood finish.....
not talking about lacquer right?Oh those clear coat for wood to make it shiny and water resistant is it? Those that you normally apply to wood using a brush?
Not sure, but some accessory shop recommend using tint film only....:hmmmm:do these things work?
Hear that Opti coat 2.0 will yellow slightly also.....Use hard coating type la. 1 year with that much maintenance is really short. I never bothered with my Myvi when Kenneth and it lasted 5! Well, it wasn't completely clear and went a bit yellowish but didn't blur up.
Yup....Oh those clear coat for wood to make it shiny and water resistant is it? Those that you normally apply to wood using a brush?
Use a lintless cloth to apply. 1:1 mixture with mineral spirits. However, the weather plays a part too. If weather is damn hot then apply thinner mixture. If cold weather then 1:1 is okOh those clear coat for wood to make it shiny and water resistant is it? Those that you normally apply to wood using a brush?
Thinner means more spirit? Will protection will be thinner also?Use a lintless cloth to apply. 1:1 mixture with mineral spirits. However, the weather plays a part too. If weather is damn hot then apply thinner mixture. If cold weather then 1:1 is ok
yes more spirit. Apparently no..i guess its like wax. We cant make the wax layer thicker by waxing a few timesThinner means more spirit? Will protection will be thinner also?
Wax yes, but spar urethane is gloss layer mah! Can try paint a few layers......lolyes more spirit. Apparently no..i guess its like wax. We cant make the wax layer thicker by waxing a few times
