pros and cons of lighten flywheel and racing clutch
rinagi
634
K.L
anyone here can tell the pros and cons of lighten flywheel and racing clutch??
Pulsargtir
56
Lighten flywheel means it may hamper idle and lower rpm running but it will increase acceleration due to decrease rotating mass and increase engine braking
Racing Clutch - a bit heavy but no more slipping.....
JaHaX
1,859
8
no need to ask anymore la bro ... just go for TODA kit ... semi racing clutch, clutch cover, bearing and lighten flywheel = RM3.8K ++
hehehe
Brian_J
8
www.altezzaclub.org.au
a lot of us hear in australia are running TRD organic sports clutch and JUN lightened flywheel
this combination will have you increase throttle response and the clutch will "engage" and "grab" much more effectively
the cons i guess will be a heavier clutch and increase engine braking like pulsargti said. i also noticed a drop in fuel economy so you will be gettin about 20-50km less on a tank. having said that, i have been double clutching and rev-matching with the new clutch and fly to ensure smooth operation
JaHaX
1,859
8
ahhhh ...
talking about feul consumption ... my car can only go 380km max full tank (feul indicator start to appear after driving for 340 km) ... after i took out catalytic converter ... previously, can go 430-450km max ...
for your info ... full tank cost us RM100 ...
rinagi
634
K.L
should i say , different driver with different driving style??
during my "auto" altezza time - urban driving 300-350km/tank until red lamp
h/w with constant 110-120km/h can go until 550~600km/tank.
now with manual tranny, also same. i suppose it should be more.
Pulsargtir
56
I can get about 500+ km with my Supercharge manual tranny....it is consider very good compare to my Nissan Pulsar.
JaHaX
1,859
8
haiyaa ... need to install the v-pro fast fast ... to retune the whole ignition/feul system ... might get good result on feul efficiency ...
oic brian ... can i buy ur harness since u are not using it?
rags
8
I think the rs200 tank capacity is also 60 liters.I was able to fill in about 55 liters
ok well i may be clueless about tuning cars but i have read numerous posts and topics in this forum before starting up my own topic. iv also asked my friends about tuning up my car. anyway i have a savvy amt which not so savvy but its the best choice for my preference.
anyway i was told that my initial tune up would be an aftermarket air filter by k&n. then i went to look at a few where as theres many different types of air filters and some even with injection kits. im more interested in...
