problem in convert 20V bt into AE100 5AFE charsis.
kahwee81
703
Kuching,Sarawak
Dear Taiko,
After i brought the 20V bt hc, i plan to swap the whole hc things into my car. But jz spotted that 20V lower arm hv another xtra skru each side attach to the car charsis, but mine dun hv... So usually wat will u guys do? need to put in another nuts into our charsis so that we can skru it? Ur comment will be very much help! thanks!
KHWONG
3,937
36
1,648
if you wan to use your halfcut suspension ( macpherson or superstrut) then u need either put another nut and weld it on ur chassis or u can just drill a holes and use the nut tight inside you cockpi area.. just under your brake padel if not mistaken .
original AE100 chassis oledi got the marking of the holes which you need to do... so no need worry for the wrong holes u get.
hope this can help you
thanks
kahwee81
703
Kuching,Sarawak
Thanks bro! But if tight d nut inside the cockpit, we need to drill a big hole rite? As Din c any hole around that area....
