But some mentioned Hankook v12evo2 sidewall is soft?was about to suggest this oso. hehe. the sidewall is stiff and wet grip not too bad.
Well, different brand, different, but category should be same.....v12 is higher level than ps31 right? maybe that guy's car is heavy. hahaha
Yes.. it isBut some mentioned Hankook v12evo2 sidewall is soft?
He daily need good wet, and especially cheap. RS4 not going to be cheap.....lolmaybe he needs hankook ventus rs4
That is why he asking or better stick back to PS3.....hahhahahaRE003. hehehe
Yes, it's relatively softer.But some mentioned Hankook v12evo2 sidewall is soft?
I think Ps31 is more like entry level performance, while v12e2 is true uhp.Well, different brand, different, but category should be same.....
That is the thing, both Tire rack and UK tyre review puts PS31 as UHP Summer.I think Ps31 is more like entry level performance, while v12e2 is true uhp.
But Tire Rack review of PS31 actually concluded that it's performance fell short of true UHP.That is the thing, both Tire rack and UK tyre review puts PS31 as UHP Summer.
Then Tire rack put V12evo2 in Max and S1 Evo2 in UHP, whereas Tyre review puts S1evo2 in Max and V12evo2 in UHP.......lol
RE003 wet my balls shrink o. really. i scared. feel like aquaplane.RE003. hehehe
So actually, PS31 is what level now? hahaha. i thought its same level as V12evo2...if its cheaper..I am ok la. If its lower level and the wet cannot make it, then i top up a bit for the v12e2That is the thing, both Tire rack and UK tyre review puts PS31 as UHP Summer.
You need to try to find out. Different car and setup also will yield different results. My VR was on Land Golden LG27, unknown brand but to me is not bad for the price. Only RM220 for 215/45R17.....lolRE003 wet my balls shrink o. really. i scared. feel like aquaplane.
I'm quite sure ps31 is below V12E2 and still entry level performance because the utqg rating is only 400/A/A. No true uhp tire has tread wear rating as high as 400. The highest I know is only up to 340 for Continental ECS.RE003 wet my balls shrink o. really. i scared. feel like aquaplane.
Ok see I feel cheap or not.I'm quite sure ps31 is below V12E2 and still entry level performance because the utqg rating is only 400/A/A. No true uhp tire has tread wear rating as high as 400. The highest I know is only up to 340 for Continental ECS.
KU31 was one time Kumho top UHP tyres, whereas ZE912 is Falken Ziex range and is mid tyres only. Falken UHP tyres is the Azenis rangeOk see I feel cheap or not.
Another car using Kumho KU31, seldom used and the car not driven fast, actually not bad. Better than Falken ze912
After 30k km, almost half worn, sure aquaplaning resistance will be poorer......On 2nd set of re003. Dry performance tip top
Wet performance... After 30k shakey if pool of water at a speed of 110kph.
Still will buy it at price of rm 195 or less per tyre for 195 50 15 or 195 55 15
price is still between RM175-195/pc. 30k km mileage sure aquaplane. hehe.On 2nd set of re003. Dry performance tip top
Thread starter | Similar threads | Forum | Replies | Date |
Bridgestone Potenza Adrenalin RE-004 | Wheel And Tyre | 25 | |
E | Bridgestone Potenza RE003 | Wheel And Tyre | 177 | |
L | Reviews of BS Potenza RE002 | Wheel And Tyre | 140 | |
205 50 17 tyre Bridgestone Potenza RE001 | Wheel And Tyre | 14 | |
C | 205/50R16 - POTENZA RE001 Adrenalin | Wheel And Tyre | 0 |
