- Jun 14, 2009
- 322
- 6
- 1,518
Precision Power Industries USA High End “Rare Exotic” Flat Honeycomb 12" Subwoofer
PRECISION POWER INDUSTRIES USA (PPI) HIGH END “RARE EXOTIC” FLAT HONEYCOMB 12 INCH SUB WOOFER
Our high perfomance PowerClass Flat Piston sub-woofer PC12 which represent the extraordinary design achievements of the PrecisionPower Engineering Team. The Precision PowerClass Flat Piston subwoofers have been engineered from the ground up and are constructed in Phoenix from the finest materials available. PowerClass Flat Piston sub woofer PC12 reflect PPI commitment to “Absolutely State of the Art” performance and ultimate sonic quality.
The PC12 sub-woofers speaker incorporate a 2” voice coil, dual Layer voice coils wound onto black anodized aluminum formers. The voice coils are cooled and given increased technical damping through the use of a ferrofluid filled magnetic gap. The cooling, and therefore power handling, is further enhanced by the extended pole piece and vented magnet cavity. The long field motor structure results in a substantial reduction of distortion over conventional loudspeaker systems. Increased linearity at large excursion is obtained by using dual matched rear suspension components.
The most unique feature is the use of a flat diaphragm instead of a conical structure. The diaphragm is constructed from a combination of state of the art materials which include E-Glass and Nomex honeycomb, in result, a diaphragm that is exceptionally stiff and lightweight which does not exhibit cone flex distortion or the buckling effects inherent in conventional designs. Additionally, Precision Power chose a high grade steel basket design to complement the demands of this rugged high end driver.
- E-Glass/Nomex honeycomb diaphragm
- Stamped steel basket
- Forged steel back plate
- Voice coil/Black anodized aluminum former
- Dual complementary vented spiders
- Carbon/Nomex pole piston
- Vented pole piece
- Ferrofluid filled magnetic gap
- Power Handling 200W – 400W rms
- Net Weight 12.64lb
- Dimensions 12.00” dia.
- Mounting Diameter 11.00”
BROUGHT BACK FROM US.
(FROM ALPHA AUDIO INC. U.S.A.)
Authentic 100% item Made in U.S.A CONTACT SHAHRUL : 017 657 3570
- Vented pole piece
