Pedal Box (Maximum Response)
Ck™
946
4
518
DTE Systems developed the PedalBox in order to improve response in modern cars. The PedalBox is an additional control unit, with four user-selectable programmes, that increases throttle response by removing delays in the accelerator, enhancing driveability.
Greater control. User-Adjustable.
All drivers face a wide range of driving conditions and situations. The PealBox allows drivers to choose between four levels, each with three seperate modes offering improved response. The PedalBox includes different programmes tailored to meet the most drivers range of driver's wishes. The driver can select the programme most suited to the driving situation.
Reduced response time. More dynamic.
Moments of delay are a thing of the past. The signal is immediately followed by the response, giving the driver the feeling that he or she is accelerating faster. However, the torque remains the same. It is merely the response ratios that have improved.
Maximum efficiency. Greater driving pleasure.
Once responsiveness has improved, driving is a lot more fun. Plus, quick acceleration without any delay gives drivers the feeling of being in better control of their vehicle.
Practical and beneficial.
Modifying the values set by the manufacturer therefore has advantages. The PedalBox will meet the expectations of customers and their cars. The often delayed throttle response of modern engines is gone, while retaining the standard engine control unit.
More programmes, more flexibility, more driving fun.
With the new PedalBox V3.0, DTE Systems has once again successfully updated the PedalBox to include the newest technologies, thereby allowing the company to realise a multitude of customer wishes. The PedalBox V3.0 is now even smaller, more manageable, more effective and even more flexible in its programming.
Above and beyond the standard...
In addition to the already known four levels of "SPORT", SPORT Plus", ECO" and "OFF", there is now also the option of modifying the programme-specific response and, via a 6-level programme, adjusting it in a more individualised fashion to match driver's wishes with the "Curve Differentiation" switch.*
It's all about the driver...
In order to give the driver even greater feedback, the ergonomics of the PedalBox have also been improved. Instead of the uni-coloured indicator lights that had been built in up to now, now different-coloured lights provide information on the PedalBox' current programming.*
As individual as you...
What's more, customers can now avail of a unique service from DTE Systems.
IN ADDITION TO THE STANDARD PROGRAMMES, the PedalBox V3.0 now allows CUSTOMISED PROGRAMMING too. Together with the experts at DTE Systems, you can now have performance programmes tailored precisely to your needs.
This means that the throttle response is adapted with precision and you can get your own customised PedalBox. In addition, you don't even have to go take your car to the garage once; instead, DTE Systems does all the work for you via remote dial-in over the internet.
Sport Mode
In the Sport mode,throttle response in improved slightly.Sport increase throttle response by up to 16%,making it suitable for most situations.
Sport Plus
For sporty drivers, we recommend the SPORT+ mode. The SPORT+ mode incorporates optimal fuel consumption across the entire rpm range and is perfect for merging quickly with road traffic or when overtaking is required.
ECO Mode
The ECO mode is suitable for the stop and go of city traffic. It guarantees improved torque in the lower rpm range while the response is programmed to achieve economical fuel consumption.
OFF Mode
We recommend the OFF mode for driving on very slippery road surfaces brought about by ice, snow or heavy rain.
PEDALBOX : Response
The PedalBox is located between the accelerator pedal sensor and the control module and works by capturing the accelerator pedal signal and transforms it. Lots of manufacturers offer similar functions via standard "sports buttons". The PedalBox reduces the pedal travel necessary in order to reach a "throttle wide open" state (full throttle response). This allows the driver to exploit the full potential of the engines.
Explanation
The "Throttle Response" curve shows the speed at which an engine responds to the driver's pressing of the accelerator. Deficiencies are evident here, especially at times of strong acceleration.
Throttle response has less to do with how much power a vehicle has but rather how long it needs to fully release this power, with petrol engines frequently performing better here than diesel ones in this regard.
Usually, a naturally aspirated engine is more powerful than a compressor or a turbocharger, a fact which is however not often noticed as the cars are given different response times by the manufacturer. But even when the same engine types are compared, ultimately a difference in response will be determined, as there are a wide range of factors that influence the response of an engine.
The throttle response of a stick-shift or a semi-automatic car can be easily enhanced simply by changing gears – in the case of a small car trying to overtake another car for instance, by moving from 5th to 4th gear.
Most vehicles are equipped with a drive-by-wire system. Here, acceleration is achieved by way of an electric signal and not by the familiar Bowden cable, something that most people are not aware of. This system is called ETC or ECM. The problem is that these systems often suffer from a significant signal delay, which the PedalBox can compensate for perfectly. This means that more energy is available to the car once again.
Suitable For All : Petrol And Diesel
(Plug and Play Installation)
*While Stock Last & Limited Stock*
**RM950**
Serious Buyer Please Call / SMS
Contact : +6017 668 8171 -Ck
*Item Can Shipping To Any Where
*For Other Product Or Price Please Call For More Information.
RBP Raceborn Performance
Last week 24 and 25 of March I went to Genting, decide to go there by Cable car because feel too tired to drive alone after a meeting in KL... Then on Sunday evening about 7 o'clock, came down from Genting. Arrived at the car, as usual I check all around the car just to make sure no scaratch or dent around, or puncture tyre... SUPRISE!!!! All the file and paper at rear seat are moved, the car still in lock condition, no signal of break in from outside.... LOst a few hundred of money...
