oil filter
kaninbu
669
104
original oil filter for airtrek cost rm40
proton original rm15
which will u use if u are alwiz chg engine oil at 5000km?
stutzedward
3,416
561
I used both Proton and original Mitsu before... I don't know what is the difference. I change oil at 7500km for fully sync, no problem or what so ever.
---------- Post added at 01:55 PM ---------- 6 hour anti-bump limit - Previous post was at 01:54 PM ----------
So I mean, u can use Proton one... but make sure it's original.
stutzedward
3,416
561
Nope... I use only Mobil1... .. been using it like over 10 years now. Last time, I tried Shell Helix Ultra, Havoline, Petronas Syntium... all not too bad (fully sync)... just that Mobil 1 always got gifts... so I bought a lot at 1 go. Especially the Porsche 1:18 model cars.. I have quite a few.. hehehe..
kaninbu
669
104
actually i find 4g63 very troublesome.4.5l of engine oil.where as market all selling 4l.need to buy another 1l sumore.
stutzedward
3,416
561
Yes... so usually I buy 3 X 4L bottles at one go... then kept saving the additonal one after sometime, it will be a full one for the next oil change. Another reason why I remain 1 type/brand.
kaninbu
669
104
do u have tappet noise problem in the morning using mobil1?
stutzedward
3,416
561
err..... I never go and notice when it's cold and hot wor... I just start, warm up 60 secs and time to go already.
kaninbu
669
104
morning start engine abit noisy later it become more quiet?
stutzedward
3,416
561
Airtrek can use the same filter from Proton. But make sure you buy the 'shorter' ones cos taller ones may result in hitting the ground when going thru speed bumps or if you have TD05, it will rub against the turbo.
may i know if proton filter is using which type proton car filter? wira?
Proton filter height is standard. Only difference is size, there's two types. big and small. Wira uses the big one, most other protons is small one
Just saw the unthinkable happened to a friend. His steering wheel came off the base as he was driving the car. Good thing it was in slow heavy traffic, had it happen at high speed along the highway he might not have survive to tell his tale. After that he had to drive slowly using the T-angle spanner to the nearest car park.
Moral of story avoid these imitations at all cost.
