New car on a new year!!! should be a celebration but...another detailing trails by KC
kc2
1,354
1,410
thedetailers.blogspot.com
One of my closest buddy who make careful planning & decision to have a * New car on a new year!!! should be a celebration but.........
after months of waiting! the car finally delivered & he cant wait to get on to it ........ as much $$$ has been paid for this ride ... so much the responsibility to care for it!!!! how then should he protect investment .....to avoid this investment to be another liability instead of assets.
he was considering sending for a polishing waxing job....the commercial ones 3 hours for $300 ...or 4 hours for $400 kinda job...
Suddenly he remember some of my article at cars magazines.... and he called me to detail
new dirt on a new car discover along the way
look at the amount of dust & dirt trapped
little bit more
rain ....... & dirt
more the boot jams area
more on the rear
look at the amount of contamination picked up in such a short time
tars....& road grime
more things picked up along the way
scratches already found - another abuse - far too much insane & vandaliser found on our roads
close up
another fine scratches found on the bottom of the rear bumper
cleaning begins - deeper & getting into the detail
ONR as the LUBE
tar like contaminant, picked up on the engine hood
more picked up along the side skirt
more
rear lower bumper
do you realised that - i was wearing a surgical glove while claying - coincidently while protecting a cut on my fingers & it seems to be the best for testing surface above contaminations.....I used to see others by putting on sandwich bag in their hand gliding on top of the paint to test surface imperfection ...but I have to agree with Matt Davis Meguiars Asia "less is more" why put our paint to more stress & danger
Apparently, i found an accidental hero - surgical glove.. if you cant feel it - you wouldn't know whether to remove.....* kindly rinse off prior moving on to the next area
*can you feel the love tonight*
feeling it
then clayed it
more
almost four hours has gone ...... & so much more to do still
new car * with new contaminants
lots more work
do you get what I mean by now ...how can this new car comes with plenty of defects & how to protect it ultimately this new investment - will our ride become another liability in years to come or asset
the rescue plan was
Wash with ONR
Clay & ONR as lube
Paint & wax remover by Optimum Power clean (1:5 parts dilutions) & rinse off with water
Paint corrections with Rotary
Megs 205 with Lake country (LC) CCS cutting pads (some area Optimum Hyper Compound for a bit more cutting) Spread at speed 1 - gradually increase to speed 3 - 2nd passes relube again with ONR & a gentle brisk pass -
polishing with Megs 205 with Megs w8027 pads
Spread at speed 1 - gradually increase to speed 2 - back down on speed 1 again - 2nd passes relube again with ONR & a gentle brisk pass -
finishing with Megs 205 with Lake country (LC) CCS finishing pads
Spread at speed 1 - gradually increase to speed 2 - back down on speed 1 again (reduce strokes speed)
finishing with Megs 205 with Lake country (LC) CCS glazing pads
effortless care & one time applications
carefully corrected & polish prior coating, as it will be seal for good....any inperfection can be only be remove by wet sanding or compounding ...... no more waxes & sealant requires - ta da OPTI COAT
moving on to paint correction
here is just some of the before & after pic - many more defect pics was not taken as I was fighting against time & deadline to deliver the car
some scratches found on the hood
ta da
look carefully.......
nothing wrong...close up & proper lighting & angle
remember the scratches before
with proper lightings
more
ta da
ta da
7 hours later
the detail engine bay
before
now
protected by Optimum leather protectant
before
now
the rear lower bumper now
the micro
ta da
the macro side view
another side
just after finishing with black CCS LC pads
after all the hard works & limited time left for coating - has to do it carefully as it only require once & for all
ta da after finishing with purple LC pads
After the final & ultimate coating of protection seal
Opti-Coat is one of the latest products to be released by Optimum Polymer Technologies. According to Optimum, Opti-Coat forms a permanent coating that acts as a second layer of clear coat that bonds to all surfaces. As the Opti-Coat will seal in any paint defects or contamination on the surface, it is only sold to professional detailers who have to sign a release form before they can purchase the Opti-Coat.
Naturally, after signing a release form and reading about how Opti-Coat forms a permanent coating that acts as a second layer of clear coat,
the clarity
Opti-Coat the ultimate Protectant to the Factory paint.....
this single layer of Optimum clear coat measures approximately 2 microns in thickness. Compared to other "paint protection" sealants, Opti-Coat is more than 100 times thicker with tests showing a wax coating measuring less than 0.02 microns.
This allows Opti-Coat to effectively absorb damage that would otherwise affect the factory paint layers. Swirl marks, light scratches, chemical etching is not only decreased by the harder clear coating, but the factory paint is protected by the thick outer Optimum coating.
more
the gloss
9 hours later
ta da
time to deliver the car back
now it only require a minimum care which is a weekly wash - as it is protected by Opti Coat
now its time for celebration
thanks for taking your precious time to view again
cheers
s1tl
1,237
1,019
713
Ipoh/KL
Re: New car on a new year!!! should be a celebration but...another detailing trails b
:stupid:wa so crazy ammount of contiminents on the side skirt @@
kc2
1,354
1,410
yupp
that is the reason why new car must get proper care & not proper whack.......
As for my buddy he just want an effortless & easy care - so i have yto do a proper coating for him
all he need now is to do a weekly wash... no waxes & sealant required....:driver: drive with peace if mind :love:
I am very sensitive when it comes to knocking. I can't even tolerate a bit as I am afraid that it will cause serious damage to my engine. I myself am running retarded ignition with very much reduced knocking (still got a bit) on my 4AGE Blacktop.
However, I have friends who run on standard or even advanced ignition and asked me not to worry. I have test driven their cars and it knocks severely! It's difficult to even go 30% throttle at lower revs. Knocks very loud. But he said it's no...
