- Nov 3, 2006
- 411
- 10
- 1,518
its been a long time since i last post here in ZTH...btw...need help from u guys...my engine is EK b16A with S90 TB and skunk manifold...
the problem is every time i start up to warm up the engine...the car idle RPM just went down and the engine dies...i need to throttle and rev it for a minute or two then the car RPM will not drop but still low between 400-500 RPM waiting to reached full temp...
when it reached full temp then it will maintain at 900rpm but when the aircond is on...it will drop to 400-500 RPM again...and the engine seem like wanna dies already with the "thick! thick! thick!" sound...
i already the adjusted the screw at the TB and adjusted throttle cable...also adjusted the fuel pressure regulator...but still...same prob....
and another thing...smetimes...after when i tarik vtec...the car RPM will go crazy revving up between 1k RPM to 1.5K rpm constantly....
WTH is happening?!?! aiyoooo!
