need help bout cam.....
[email protected]
246
Brand: Tomei
Part: Camshafts, (1) Intake (1) Exhaust
Duration Intake: 260
Duration Exhaust: 260
Lift Intake: 11.20mm
Lift Exhaust: 11.20mm
Part #: 143042
Engine: NISSAN SR20DE S14,S15
hello to all sife...would like to ask wherther can use this tomei cam shaft on my stock engine....?do i need to change valve spring or cam chaft adjuster..??thankz
slide_it
238
10
anything above 270 would require change of springs.
256 and 260 are drop in cams from tomei
Md Ekal
91
6
508
Gurun/Kedah
Brand: Tomei
Part #: 143042
I want to know la.....
If this set kaco a/cond o not???
n how bout engine idle???:hmmmm:
Nats autoparts
411
20
please check on the web page to determine the cam spec..
if pon cam doesnt need valve train change
if pro cam does need
please follow guide base on Tomei Web page to guide you the way of modding you engine..
enjoy!!
I was wondering anyone here can help with my little small project...
is a ek3 with B20B Vtec (b16 head small vtec oni)
the tranny shift fine and very smooth if drive normally ...
but when WOttttt ~~~ (pedal to metal) especially when transmission hot the rpm will reach 8.5k (which is rev limit) the gear hesitate to changes ... untill i release the pedal for few sec and reapply baru changes...
but i check the tranny fuild very nice ler... ( red and fresh ) lvl also cun... no leaking no...
