MX-5
Autoracingsyndicate
46
:rolleyes: Guys is a mx-5 good enough 4 drifting?
saw those import mag. which stated tat mx-5 is very good 4 drifting .....light n small..... :unsure:
ZeE
157
www.drift.com.my
i think the problem 1st of all is the older version are 1.6 i think and its pretty underpowered ?
but the current 1.8 and the new turbocharged version should be a hell lot better.. yeah as long it has LSD, should be a fun drift softtop :)
Autoracingsyndicate
46
:) Insert an aftermarket supercharger into the 1.6 engine might b good enough....my 2 cents ...
SiGNAL
819
Ya Mum's House
MX-5 has viscious lsd.... so probably need to change the lsd to an aftermarket unit. Yeah i think 1.6L is pretty underpowered. For those hardcore mx5 fans, can consider 13B swaps.
Kurt
201
the 1.6 can drift also ler..but its really underpowered .. 116hp is not enough..
but if you turbocharge it and with lsd then different case.. :D
.S K A G E E.
803
Is it safe to assume that someone will be making an appearence soon? :)
BLaCkHoWLiNG
'(^^)|Most Awesome Member
8,648
1,349
PJ
www.autojunctions.com
sounds familiar... hmm... lemme see.. errmm.. umm... u mean.. err.mm.
like wat u did la issit? :P :P :P kawkawkawwkaw
:ph34r: :ph34r: :ph34r: :ph34r:
Autoracingsyndicate
46
:) Guys wat if i mod the mx-5 1.6i ....just 2 gif it more power n torque can it b a good drift machine....
Kurt
201
skagee,
when are u going to teach me how to drift lar? :D
now clutch slipping.. can't do shit.. waiting for clutch to arrive....
blackhowling,
:P :P :P
Autoracingsyndicate,
1.6 more power and torque ar? easiest solution is to turbocharge it... for more info you can visit http://forum.miata.net/cgi-bin/ultimatebb.cgi and check out the Power Mods section...
hi all sifu-sifu
a noob question here. a Pivot Speed Meter actually for wat use har?:confused_smile: or it is only a digital speedo meter. Rm400 good buy?
pls advice.
thanks and regards
