mitsubishi eterna twin turbo 2.0 v6
freestyler0708
82
i`m using mitsubishi eterna twin turbo 2.0 v6....my turbo boost only 0.4 and my car never modify b4..so what can i do?? i`m newbie and know nothing...pls help..!!
alvin24
3,109
27
5,148
u can do anything and everything...
its like asking what can i eat?
Perdanalusuh
40
Get a fuel regulator , boost controller and AFC. I think 1.0 bar already OK. Just bring my v6tt to service and when the mechanic open up the hood... the engine is full of spider webs... my V6 is like my house deco... seldom move... : )
kob3bryant
484
fuel regulator is mechanical type,juz for controlling the fuel output.
safc is electronic control ur fuel and air mixture ration,for prefect of combustion.
mag9556
2,770
43
1,648
Fish bone... also workable...
ben_gsr2s
328
Offshore
freestyler0708 said:
fish bone????
fishbone... in malay "tulang ikan"... the term that widely use...
it's a mechanical boost ctrl..
tuned
Noob
731
Shah Alam
well..its does sounds a bit strange...as 0.4 bar is quite low even for stock boost...
eterna versions of the twin turbos should be achieving 0.6 bar or so at stock...
is your exhaust upgraded when you converted? else, probably you should get it check out...could be some parts not functioning well...i.e. plugs, cables, ignition coil...
if you r from the klang valley, then maybe i can recommend u my frequent workshop that converted my twin turbo for me back then...PM me if you want the contacts...
anyway....
to upboost, u probably...need a larger fuel pump, a boost controller, an open pod filter, an AFC, not forgeting a FCD....this should be sufficient for a decent upboost...as stock ECU would cut at 1 bar...
happy modding...cheers
Hi all
I got 1 iswara 1.5 year 1990 need to uprade engine. Please advice which engine is suitable and easy to maintain on my Iswara. I'm planning to change it either to 4G91 or 4G92. Any info on which shop who can offer me the engine with the installation? Please give me info. Thanks.
