meter panel
mi_scuzi
219
Selangor
hello guys,
currently i'm using proton OEM dashboard with proton 1.6 meter panel..can i maintain my proton OEM dashboard meanwhile i install a mitsubishi meter panel,izzit possible to do that?thank you :biggrin:
cheers
badguy
951
it is possible but will leave a significant hole there loh!
and wiring is not the same and need to modify
Stewart
236
kl
hey guys..sorry just wanna tumpang ask at ur thread..
i would just wonder can i transfer a mitsubishi just the rpm meter panel into proton meter? with all the speedo,fuel,tempreture all those remain...
badguy
951
wah that means u want to cut half of the meter loh!
DarkAccoon
880
432
3,063
not too sure about inserting the mitsu rpm into the wira panel lorrr
depends on which year of wira are you using
if siemens ecu (year 2000 and above)
you might have a problem
if below that year then should not be a problem
but do note that mitsu is using screws to complete the circuits while wira oem panels uses sockets
if not mistaken (mitsu = 3 connection points) whereas (wira oem = 5 connection points)
jigc
99
to replace proton VDO meter with MMC meter is possible.
but u need to change most of the pinout of both connector.
there r 2 big gap at top corners as mentioned. :D
WAJA2003
2,107
22
Shah Alam
mit meter saperate to put in wira meter???
i think cannot worrr,bcs behind the eletric road all not same worrr...
Stewart
236
kl
haha.. i'm using yr 97 1.8 engine.. but still with the old meter where the rpm meter couldn't use.. so i was just wonder if only changing the rpm meter is possible..
by the way.. is that possible that oem's 5 connection point change it to mitsu's 3 connection point?
thanks for sharing ur knowledge...
DarkAccoon
880
432
3,063
not too sure
tried it the other day
blew a fuse and i gave up
but since you are using a 98 version of wira
which means.... mitsu ecu (lucky man you)
just go to those kedai alat ganti kereta (NOT CHOP SHOP)
get a new rpm meter panel
if not mistaken new one is about RM 140
better than trying to integrate a mitsu rpm into it
Stewart
236
kl
ohh those spare part shop selling the rpm meter alone also? haha thanks bro... i think i better get a new 1.. less headache ma.. :biggrin:
and ur rpm meter is 8000rpm or 9000 rpm ar?
jigc
99
to ppl who r interested to replace ur VDO meter panel with mmc lancer meter panel, this may help.
This question is to all the sifu's out there.
What i heard then common thing now is...
most ppl use MIVEC with a 4G93 block rite?
but i wanna know, is there a stroker kit for the 4G93 block that can increase the displacement from 1.8 to 2.0 maybe?
and what other mods that can be done to the MIVEC engine.
I am planning to dump in a MIVEC engine.. actually tot of using a 4G63t
but cancel plan la...
Here's the mods that i am thinking of:-
1] MIVEC with 4G93 block
2] Change in...
