MAP or MAF sensor questions
oonbc
334
evo
hi,
can someone educate me abit about MAP or MAF sensor for a piggy back? and what is the difference a piggy back with or without it? is it essential?
i dono how to put it correctly, hope u guys understand what i mean... thanks.
ecupro
323
6
oonbc,
You quote:
"can someone educate me abit about MAP or MAF sensor for a piggy back? and what is the difference a piggy back with or without it? is it essential?"
Well, the MAP or MAF sensor for a piggy back is to re-calibrate the output signal,like fuel map, rpm X load ( map or maf )
Example, a 1600cc engine, you re-bore to 1800 cc. Since engine cc increase, you alos have to upgrade your injectors, say from 210cc to 285cc.
Now, when you want to idle the engine, the A/F show very rich. What you can do is, you have to reduce the MAP or MAF signal from the input table according to rpm and loading.
That mean MAP or MAF will reduce the signal and feel to the stock ecu, then, the stock ecu will re-calcualate the volume of the fuel in order you have smooth idle.
If you re-gain the output signal from the input table, you will have bad idle for your engine.
For cheap side, you can re-chip or burn the eprom after mod the fuel and ign table like Honda VTEC, software editor like CROME.
Goodd Luck.
Joeker
Walking Dead
3,580
62
Jinjang
oonbc said:
hi,
Regardless whether its a standalone, piggyback or stock engine ECU, the job of the MAP or MAF sensor is to relay information to the ECU about how much air is present in the intake manifold.
Unless the engine is carburated, without the MAP or MAF sensor, the ECU is as good as blind.
A Post Every 5 Mins
guys, whats the stock standard cam angle measurement for 4g91,92 and 93? any one knows..i tried searching all over the web, dissapointing..thanks guys..
