i just get manual boost controller, works engineering type. but i don't know how to install it. this is my picture of it. anybody help
For stock turbo with actuator.im using it..... tat's a hose connected to ur internal actuator....
tap from there....
throw away ur actuatortanks dude, but i'm using tial external waste gate, it is ok to use original air filter for up boost? help
Ok, u get the hose that connects the intercooler piping/turbo outlet to the wastegate and have the boost controller connected there.tanks dude, but i'm using tial external waste gate, it is ok to use original air filter for up boost? help
No need T. The tulang ikan valve is already bleeding pressure to the ATM.*wanna ask info on tulang-ikan (aquarium oxygen valve)
-the orientation to install which position???? is it sandwiched between wastegate and boos pressure????
or is it install using "T" which leaks boost pressure to atmosphere before going to wastegate??
From wastegate / actuator got one hole there, put the vacuum hose there and join the tulang ikan in the middle of the vacuum hose, and continue the hose to the intercooler piping (make one hole there near to t.body, after the B.O.V. holes)*wanna ask info on tulang-ikan (aquarium oxygen valve)
Please top up some more if my explanation is not clear..hehe.
