LSD Gearbox, what it's all about?
aalto
406
93
3,028
go search in wikipedia, search > limited slip differential :wavey:
mytowerofpower
31
The main advantage of a limited slip differential is shown by considering the case of a standard (or "open") differential where one wheel has no contact with the ground at all. In such a case, the contacting wheel will remain stationary, and the non-contacting wheel will rotate freely—the torque transmitted will be equal at both wheels, but will not exceed the threshold of torque needed to move the vehicle, and thus the vehicle will remain stationary. In everyday use on typical roads, such a situation is very unlikely, and so a normal differential suffices. For more demanding use, such as driving in mud, off-road, or for high performance vehicles, such a state of affairs is undesirable, and the LSD can be employed to deal with it. By limiting the angular velocity difference between a pair of driven wheels, useful torque can be transmitted as long as there is some traction available on at least one of the wheels.:confused:
Two main types of LSD are commonly used on passenger cars; torque sensitive (geared or clutch-based or cone-based as shown in figure at top of page) and speed sensitive (viscous/pump and clutch pack). The latter is gaining popularity especially in modern all-wheel drive vehicles, and generally requires less maintenance than the mechanical type:banghead:
---------- Post added at 02:54 PM ---------- 6 hour anti-bump limit - Previous post was at 02:49 PM ----------
and some types of LSD :itsme:
tofu_manic
1,342
91
5,148
anyone know about helical lsd?
like the mechanical helical lsd from the s15, when cornering, when the inside wheel breaks traction it will send power to the loaded outside wheel
without the lsd, the less loaded inner wheel would eventually start frying itself when u try to go faster and faster
Good day,
I have a 2000 year corolla Ae111 4AFE which has a faulty crank pulley. It caused my crankshaft to be replaced as well.
May i know where can get original toyota replacements? Or with the same price, i should get something better?
Its a daily driven car, i like it to stay stock. :wavey:
Im at penang.
Thanks All Sifu~
