lowed spring coil
master_flexs
41
which way is better? cut the spring coil or burn and compress it? and how much is it cost? tq.
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
cut spring=no,burn spring=big no no,compress it=bouncy.go buy urself sprot
spring lar bro.cheap only what.rm1++ also can get already.
boyzone
2,669
38
5,148
Look for cheap spring with good performance?
I have a set for wira 1.3 / 1.5 lower sport spring.. is from Germany and only want to let go with RM150. Comfort spring.
dennisdreams
333
21
there's a bit of 'blur" definition in "sport spring", some define it as "spring to lower your car", "spring to enhance your car's performance", "spring for motor-sport/competition usage" and so so. normaly the spring we could find in the market is "spring to lower your car" which is cheap, RM100~ RM300 range, which had a lower stiffness rate, and slower respond compare to stock spring. And "spring to enhance your car's performance would varies from RM500~RM1200, depend on brand and quality, which had higher stiffness and faster respond compare to original spring. And lastly would be the "spring for motor-sport/competition usage" which we usually call "coil over" which comes with absorber who sit at 1500~2000/set(spring only) with exceptional build quality, minimal stiffness-fade and very fast respond.
strangex2
238
If the "spring to lower your car" havs lowers stiffness rate, at it's lower than the stock springs, ... then kena la bottom out loh? I thought lowered springs are stiffer than stock springs as they have less space to compress?
singchaii
687
Pandan Jaya, KL
Brother, don't try to cut or burn the spring.. Later you suspension will become worst. Is you compress it, it will bouncy. Why don't just get lowered spring? How low you can to do? Like VIP style? Hehe.
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
ur right.lowering spring r stiffer then oem.
JaSON5878
98
Remember to match ur lowerd spring with higher rebound damping force absorber. If not, ur ride will become bumpy.
dennisdreams
333
21
true~ if the spring's rebounce rate is low, you need to increase your absorber's damping duty to reduce the chances of your absorber "touch bottom"
strangex2
238
Maybe next month I will buy a set of APM performax spring for my Kancil and just change to front and match with it my stock shocks. Running on 14" rims with 165/55.
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
is it just me or other experience it to?no matter how u change the kancil
suspension,u ride will still be bouncy.even on stock,when u hit a pot hole,the
dash vibrate violently.unless u prefer handling then comfort.:)
Background Info : I have a Proton Persona SE and have recently changed my exhaust system, about 2 weeks ago; changed the tensioner bearing last week;and I got new rims yesterday, changed from stock.
After changing the rims, I kept hearing a sharp, high-pitch, high frequency sound inconsistently from the back of the car while driving back. I I fear while testing the damage was caused during testing the rims. The new rims seem to work fine. But the inconsistent hissing/screeching noise did...
