bro..from what i've known knife edging of the crankshaft is for lightening purposes and also less windage losses..means that bcoz of we are using wet sump configuration so there will be oil in the sump most of the time unlike dry sump..so they usually knife edged it to make it cut through the oil like knife thru butter..hehe sorta..but downside is other than what the sifus has highlighted, there are also problems of harmonics at high engine speeds..it wud bcome unbalance then the crank might take a "walk" hehe..that's why some tuners like AEBS prefers to have full counter weight just like in F1..just sharing what i've heard..feel free to comment..sifus out there!!
i need to know what are the downside to knife edge crankshaft lightening?? better to know the downside first i reckon.and what are the goodsides?? i'm re building my engine,so kinda have this in my list.thanks!!
eheh...crazy import tuner in the US...AEBS?? anyway...good review...more reviews welcome!!
for turbo engine or n/a ?sifus out there!!
the thread is mainly about knife edging,which in a way brings to some sort of trimmings that causes lightening.for turbo applications,u dont actually need heavy conrod and cranks,just solid ones.now u can find billet cranks and rods as an upgrade to forged materials.billet still light but can withstand higher boost and abuse.just my 2cents.lightening is not for turbo engine..n/a yes good for it..turbo engine just balancing..turbo engine need heavy crank n rod to play hi boost and hp
woww!! great info there mate!! thanks!!There are a lot of crank cutting design which is good, the normal knife edging, radiused type, bell type & radiused.
1) Knife edge will give you instant pickup but no top speed.
2) Radiused will give you good pickup with top speed
3) Bell type is good for sprinting for the first 3 gear & mid 4th gear only. Then power loss.
I'ts a matter of preference,,,now you can choose your power type guys.
Errmm..so, which shop inthe klang valley is good doing radiused cranks?
