MOHAWK, KICKER, JBL, BOSCHMANN- Complete Used ICE
Hi guys.... I have some used ICE for sale here. I need to let go just because up-graded. All still in good condition 9.9/10. Quite complete for whole car. Have woofer,amp,2-way speaker and tweeter with cross-over. ALL is branded and 100% ORIGINAL.
1) KICKER Comp C12 Subwoofer 12Inch With Box (RMSOLD)
2) MOHAWK ms100.2 silver 200w rms 2 channel amplifier (RMSOLD)
3) BOSCHMANN RSX-650E 2-way System Speaker (RMnego)
4) JBL - GTO18T Dome Tweeter (RMSOLD)
ALL the item price still can nego until let go. If take ALL, i will give a special price for you until satisfy. If interesting or need any information kindly PM or direct email me, [email protected]. NO POSTAGE. COD can make at CHERAS, PUCHONG or KUALA LUMPUR. Below have some picture and spec.
KICKERComp C12 Subwoofer 12Inch With Box (RM SOLD)
Specifications :
Model: COMP C12
Size (IN.,CM) - 12, 30.0
Impedance (OHMS) - 2, 4 or 8
Max Rec Amplifier Power (WATTS PEAK/RMS)* - 300/150
Sensitivity (dB 1w/1m) - 88.3
Frequency Response (Hz) - 27-500
Mounting Depth (IN.,CM) - 5-7/8, 14.8
Mounting Cutout (IN.,CM) - 11, 27.9
Min Rec Sealed Box Volume (CU. FT., Liters) - 1.25, 35.4
Max Rec Sealed Box Volume (CU. FT., Liters) - 3.5, 99.1
Min Rec Vented Box Volume (CU. Ft., Liters)** - 1.75, 49.6
Max Rec Vented Box Volume (CU. Ft., Liters)** - 2.25, 63.7
*Assumes typical music program with minimal amplifier clipping; varies with enclosure size.
MOHAWK ms100.2 silver 200w rms 2 channel amplifier (RM SOLD)
Spec: * Power Output (Stereo): 100W RMS X 2
* Power Output (Mono) : 200W RMS X 1
* Signal To Noise Ratio > 90 dB
* THD & Noise < 0.05
* Speaker Impedance : 2 - 16 Ohms
* Frequency Response : 10 Hz - 20 kHz
* Input Sensitivity : 2 mV - 5V
* Low-Pass Frequency : 40 Hz - 150 Hz
* High-Pass Frequency : 40 Hz - 300 Hz
* Bass EQ : 0 - 18 dB @ 45 Hz
* Input Impedance : > 20k Ohm
* Fuse Size : 30A (2 X 15A)
* Dimension (MM) : 320L X 60H X 250W
BOSCHMANN RSX-650E 2-Way Speaker (RM NEGO)
SPEC: RSX 650E
6.5” RSX TM series Coaxial Full Range 2-Way Loudspeakers
Main Diaphragm Dimensions : Ø160mm
Driver Type : Coaxial 2-Way full range loudspeakers
Peak Power Handling : NA
Rated Bandwidth (+/- 3dB) 60Hz – 23,000Hz
Amplitude Response : NA
Sensitivity (2.75v-1m) : 91dB (@1w/m)
Voice Coil Impedance: 4 ohms
JBL - GTO18T Dome Tweeter (RM SOLD)
Specifications:
-25mm Grand Touring Series MyTi Dome Tweeter Component
-Power Handling:Peak: 210 Watt
-Mylar/titanium composite dome tweeters
-I-Mount for simple and versatile installation
-12dB Crossover network
-Frequency response: 2,500-21,000 Hz
-4 ohms impedance
-Sensitivity: 92 dB
-Cut-out diameter: 1-3/4"
-Top-mount depth: 16mm
Specifications :
Model: COMP C12
SPEC: RSX 650E
Specifications:
-4 ohms impedance
-Sensitivity: 92 dB
