Kenari Engine Vibration Help!!!!!!!
Oct 14, 2016
4
MIRI/SARAWAK
I just fixed my kelisa vibration issue lately. Guess what, your ignition coil is nearly out of order. At first, I also kind of headache to figure out what is going on with my car shake like hell. I took out 3 of the spark plugs. Found out one of the spark plug is wet. I was suspicious that the ignition coil not function properly. Then, I went to half cut shop and bought a second hand ignition coil. Changed it. Man, so lucky, the engine no more vibration heavily and run smoothly feeling like new. This is my case. Hopefully my situation can help you guys.
aHLengChai
380
53
great info mate.. will check mine birdie kenari then... at what price do you get the ign coil? taken from which daihatsu model?:listen:
and any driving symptoms before do the investigation? shaking on idle or in D mode?
4
MIRI/SARAWAK
Hi, sorry late reply.
It is Japanese half cut items. I got the price for 70 ringgit per piece[of course, bargain with it].
Err... not sure which Daihatsu model. But, got written Diamond there.
Driving symptoms: probably less power when you step the gas pedal. Also, shake like hell on idle and in D mode. That's my previous situation. Hope that helps you.
Good luck.
If problem still after changing the ignition coil, I guess it should be your gearbox worn out already since so many years of your car. Normally, auto transmission gearbox can only last about 10 to 15 years if proper care.
aHLengChai
380
53
i see. my bird on idle just fine.. u cant even feel the engine is running.. except while on D mode.. and when acceleration.. the power is still there with myvi lagi best 14' wheel combo with 175-65-14 myvi oem tires..
Hi,
Im just curious, based on my recent and previous experience, I noticed these seemingly nice sales man will end up screwing up their sales by being pushy; in my case at least la. Does it really work in securing sales being so pushy?? whats their intention?? to makan deposit when people change their mind??
I recently decide to look for a ride since I got a nice number plate. I thought times have change and car sales man would be more professional and more refine. In all 3 place I...
