hi all, don't worry, this discussion is also for sharing and learning only. i'm also just sharing what i've experienced.
ok, let me try and answer some queries. lifters (aka hydraulic lash adjusters = HLA) are designed to be pumped up (i.e hardened without free play) via hydraulic pressure...in this instance, via our engine oil. this is to facilitate the profile of the cams. the HLAs hardens so that the cam profile can push down on it which it would then push down on the engine valves, opening it. the bleeding of engine oil out of the HLAs (or decompression) are designed to occur automatically when the cam profile changes its cycle (i.e when pressure is released from the cams on the HLA), and when this happens, pressure is released from the top of engine valve...closing it.
i cannot correctly predict what will happen to the characteristics of the lifters once out of the engine, because of a couple of reasons:
1. HLAs are supposed to operate at OEM spec when totally immersed in engine oil
2. HLAs are designed to operate in conjunction with the engine cam profile it was designed with. this may also includes all force and pressure surrounding the HLA and cam.
3. Like our fellow forummer, i too have had experience with different compression strengths/characteristics on my HLA when taken out of the engine. this is despite immensing the HLA in engine oil for 1 week prior to testing the HLA. from a set of 16 (16 valve engine), some was totally soft (i.e looks as though it wasn't being pumped up at all!), but some others became very hard. i even dismantled one of the HLAs and had a look at the piston, ball bearing and spring in there. and i had a good look at the inlet hole. i put the same set back on (with the exception of the one i dismantled...i took another via a spare block i had), and my engine was clacking like crazy!
Now...with the same set of lifters as above, i added washers /shims on the relief valve spring and voila....problem solved. no more tik / tap / clank / chatter...even with dirty oil! (i now run my semi engine oil up to 12k km just to test the dirty oil theory on HLAs). till today, no sound and engine runs like a well oiled precision machine :). in short, i would say that it would be very hard to determine if the lifters are in proper working condition via the finger testing method.
which leads me to the next query by another forummer, on the failure rate of lifters / HLAs. The reason i commented that it won't fail is because of the design of these lifters. all components in the lifter itself (housing, ball bearing, cap, spring) are so small that it will take the highest precision engineering tools, equipment & material to manufacture. as far as i've researched on HLAs, the only possibility for a HLA / lifter to fail is when the spring inside there snaps into 2. now considering the size of this spring (for those who had seen it), it is near impossible. to help visualize, split a piece of A4 paper into 2 and its easily done. try and split a paper which is 2/10 of a centimeter, and you got your work cut out. now imagine the piece of paper to be a high precision spring (which is also quick thick !) and so i come to conclusion that it will take a significant amount of unusual force to break the spring, and this should not occur from the normal usages of the engine. that's why its important to note if the engine has overheated prior to diagnosting the lifter problem as it may give rise to a lifter failure, resulting in ticking noise.
from my reading, the HLAs / lifters when first appeared was considered to be the biggest leap in engine design since the combustible engine was used. the smoothness. quitness and 'almost' maintenance free lifters convinced most major car manufacturers to employ the HLA / lifter over its predecessor rocker arm design to control the opening and closing of engine valves. to the forummer who commented that no parts are designed to failfree, then i must say that this is indeed an excemption. it was truly ingenious.
unfortunately, this one part came with a condition, and that is that it needed constant engine oil to operate. this was the job for the oil pump, specifically oil pump relief valve (even more specific was the spring inside the relief valve), which the designers did not pay enough attention to. yes i've also read the technical publishings by manufaturers (Mazda, Mitsu, Volve & others). most have recommended to carbon clean top engine (which i've also tried), followed by replacement of OEM oil filters and engine oil. some would recommend changing the HLA itself. Mitus has gone so far as issuing redesigned lifters with larger inlet holes. again, Mitsu's recommendation correctly highlights that the ticking noise is a result of oil starvation and the bigger inlet holes was meant to 'solve' the problem. as explained in my previous posting, this will only help temporarily as the spring inside the oil pump relief valve will get softer and softer, hence less and less oil being retained in the engine block. lifter noise will return.
to the forummer who commented on changing the oil pump to a high flow pump, that is precisely what the lifters / HLAs DO NOT want. again, lifters work when flooded with oil, on a constant basis. the high flow pumps (as used in race engines) are designed so that oil is constantly moving upward and downward on the engine block for the purpose of cleaning (via the oil filter), cooling and perhaps reduction in load forces for the engine to rev higher and faster. these pumps are suitable for race environments. unfortunately, as the spec is defined, the high flow movement of oil leaves little oil retained in the block, not so good for lifters. hence, ticking sound will still be there, in fact, it could be worse. i'm not too sure what was it that you've shimmed on the oil pump, but again i must highlight that what i've been commenting about is very specific to the oil pump relief valve spring. nothing else. to add shims on the lifters would (IMHO) not be good on the cycle of the cam as this would incorrectly open and close the engine valves and would affect timing. but then again, so would ticking lifters (contrary to what mechanics say, i find my engine timing to be so far off when ticking is evident that my car runs like crap! power is totally lost.
once you've solved the lifter noise, better yet, the oil pump relieve valve spring rate, engine power is restored. i must say, when spending money to fix, go for the cheapest option 1st...which is adding washers into the spring seat. if that don't work, replace the lifters if you must. hope this helps and i welcome any feedback by fellow forummers :)
---------- Post added at 10:23 PM ---------- 6 hour anti-bump limit - Previous post was at 09:51 PM ----------
nice sharing. in case where the noise came out when the engine is cold and seldomly came out when the engine is hot, what would be the source of problem here? does it mean the oil is too thick when it's cold and getting right viscosity when it's already hot?
bro,
in this scenario, my best guess is somehow the operating temperature of the engine and engine oil is affecting the flow characteristics of the engine oil inside the block (i.e up and down movement). it is likely that when hot i.e expansion of liquid, oil volume is increased, hence retaining more oil in the block, slowing down the flowdown of oil to oil pan, resulting in more oil for the lifters to use. that may be why lifters quieten down when at 'normal' operating temperature range.
hope it helps.
---------- Post added at 10:31 PM ---------- 6 hour anti-bump limit - Previous post was at 10:23 PM ----------
so, it was an oil pressure issue den tony? nice..
hi bro,
sorry it is not pressure that is the determining factor. of course the oil pump has to firstly be working in its normal psi readings to pump oil up to the block. more importantly, the oil must stay up in the block (i.e oil don't flow down abnormally). by flowing down abnormally, there is no oil being retained up in the engine block for lifters to operate.
hence, it is the flow which is the issue. and the flow of oil downwards back to the pan is controlled by the oil pump relief valve.
hope this clarifies.
