How to reduce engine noise?
johndoe
345
I'm driving a wira 1.5GLA. bought it in 2001. But now the engine noise is louder. Anyone knows how to reduce the engine noise?
rodneyk
412
Penang
ermmm off the aircon?
use a better engine oil?
tune the engine?
so many things
hehehe
gary
255
subang
you can turn off the engine? ;) ahha.. but seriously,
what do you mean by engine noise is louder? and are you sure? 2001 till now is a long time, you probably couldnt remember exactly how loud the engine was at that time compared to now unless you measured it with a DB meter.
is there mechanical noises? abnormal noises? .. or just overall noise? how often do you service your engine? engine mounts ok?
johndoe
345
I mean compare when i first time bought the car. now the engine noise is probably 50% louder than 4yrs ago. The noise is from the engine area, when u lift up ur bonet, that's the noise i meant.
rodneyk
412
Penang
you already said its 4 yrs ago
50% is also very subjective
also another factor is your engine efficiency would have gone down.
or it might be your tuning.
go check it out and see.
We could not help you to pin point the exact problem as there are many variables.
ANDY_RESORT
820
www.andymervingeorge.com
Get the engine tuned if its on carb. Check all mechanical parts and make sure they are properly lubed with WD40. Check all devices that has ball bearings (compressor, water pump, fan belt pulleys, radiator fan motor, cooling fan motor, etc)
Good luck, just my few cents. PM me the results after problems solved ok ! ;)
