Originally posted by MetalZone@Apr 8 2004, 01:34 PM
u can just use windows' sound recorder to do it...
but the recorder stops every minute... but by pressing record again, it will continue. therefore to overcome this, unplug all microphone and line-in stuffs, click record. it will record a blank recording. then it will stop after 1 min. press record again. repeat this process until u get the desired length. u can save this file to be used as a template file. after ur done, go back to the start of the blank recording and record over it(after plugging in ur line-in of coz).
this program can also crop ur file. then when saving, set the desired sound quality and frequency. (frequency is normally 44.1KHz)
another simple prog u can use is nevo wav editor to edit the files.
