How to install Strut Bar(Zenden) in a proper way?
cck2228
Sandakan,Sabah
Anyone can teach me how to install strut bar(Front) in a proper way?
Im going to install it my self..Lazy to bring to Workshop to intsall it for me :D
Pls tell me the step how to install ok.:)
simple procedures onli lar....
i DIY installed my Ultra Racing strut bar last time... 4 points somemore...
for wira... just remove de 2 nuts at de struts there... then fit in the bar... then screw it back tightly... done...
some cars are a little different...
i still not understand.. is it remove the 2 nuts of the strut which conect the bracket?
How about the nuts on the absorber there?
how about when i need to install the bracket into the absorber nut there?
Explain oki...
bro...
jus unscrew the 02 nuts attached to the top of the absorbers mounting,install yr strut on top of it,then tighten back the 02 nuts on top of yr strut..do the opposite side...voila!!!Done!!!
Don't remove the STRUT nuts k bro!!!jus yr absorbers ones!!!
Goodluck!!!
suddenly i feel that removinga few nuts and replacing them sound so difficult... :D
Just do it lar brother.
depends on wat car... some car de strut bar mount at de absorber nut.. like saga n iswara...
Solly ah..I divert from the topic a bit
guan/drex : did you two change your bushes or arm brackets or whatever you call them after you install strut bar? I understand after you install the stress on certain components of the suspension is greater and more prone to wear and tear
Izso,
just plug n play lar... no changing stuff... just remove nuts n install...
additional wear n tear? no lar... mayb make u cornering more.. then wear ur tyre more lor... kekekek :D
mie77 said:
bro...
Goodluck!!!
Oh.. i see i see..but my car got 3 nuts..hehe..
so..i jus unskrew and skrew it rite...
Anyway...thanks a lot Mie77 :D:D:D:D
Wah.. u so bad divert my topic!!! But nevermind la... also related to my topic too..
At least i can know and learn somethings from u guys!!
Better know than don't know lar.. :D
careful with ur strut bar distant,
example my kelisa2005, the fuel injection is about 1 cm to my strut bar, i scare the injection shake and hit the strut bar so i put washer to higher up the strut bar. thats how i fix my problem. not just install had to see got blocking or problem of hitting by other things.
becuz the strut bar is design for old kelisa before 2005, so the old one is lower abit, but this new one is higher abit so very close to the strut bar. :p
yeah... how come the bar will obstruct with the fuel injectors??? or your intake manifold??? which one... pelik-pelik....
hm....it is so easy meh..hehe...i try i try..
Hmm...the topic submitted by Kiansan quite interested leh... why it will hit the fuel injector?!! Got such thing meh? i nv heard wor.. got picture? Post it
wait~~~ i taking~~ :)
hmm mine i losen the strut bar screw abit the only fix it then screw it back tightlor
Someone take pics and post here pls.. I wanna see.
Btw, does anyone know the major differences between branded and capalang struts? Websites talk about the thickness of the bar and all, but I'm yet to be convinced.
this is my car strut bar.. just remove the nuts on de strut and bolt on de firewall... then fit in de strut bar.. n put back the bolts n nuts in place... tighten it...done!!
but my car need to modify something... need to relocation de siren n another thing...
http://khguan.fotopic.net/c441252.html
A thread every 60 seconds
