How To Dismantle the Saga LMSS meter housing
suchap69
88
anyone had tried to open up the new Saga LMSS meter housing?
i want to install a dimmer so that i can dim the spotlight within the meter housing during long night driving, the light is so bright that it tires up ur eyes especially when ur driving in unlit trunk road
anybody wanna share the experience?
frcgrey
196
selangor
hi,
try to ask the EON see whether they can help you or not...
because as i knew that those L.E.D light bulbs can't add any dimmer to dimm it...
or do you hav any friend who had learned before those electronical course??if got then ask them,maybe they can modify it for you...
GOOD LUCK...! ;)
I
Indecided
Guest
Who says LEDs cant be dimmed? LEDs are as easy to dim as child's play is to us adults. Wire a 500 ohm/1k ohm potentimeter up to the lighting input.
Diagram wise, pretty simple. But i can't teach you how to rewire the unit because i dont' drive a saga. :)
suchap69
88
i know how to put in the potentiometer, just that i don't know how to open up the meter cluster, and afraid that i might broken it, can't see any screw.
thanks for all posts anyway
extreem
18
johor
my friend only put the black tinted for headlamp to the meter panel..then the bright will kurang and comfort when drive ......have nice diy.....
suchap69
88
i've done that bro,
put one layer, slightly dimmer but still hard on me eyes
the i put two layer, can't see anything during daytime
so i revert back to one layer but still tiring
my best solution now is to put black/dark cloth, still can barely see the orange needle, i know when the needle is 12 o'clock the speed is bout 100, 12.10 = 110kmh
sapa2ler
179
no need to open the housing.......
u can dimm the light..... on ur headlight........ press the meter reset button, will make light brighter or dimmer
** meter reset button function **
- to reset meter (headlamp is off)
- to dimm or bright the meter light (headlamp must be on)
LAWRENCE_Q
428
JB
got such secret behind???? mz try :regular_smile:
suchap69
88
nice to see replies after a long time
mine is actually lmst so the tripmeter reset button is a push button type as it is digital, is this tweak still applicable?
thanks for the replies anyway
Hi. Im planning to change my neo steering to a preve steering. Anyone done this before? My only concern is the airbag swapping to the preve steering. would it fit?
