Originally posted by MetalZone@Aug 3 2004, 02:58 PM
hi guys... any tips on how to clean the engine? use what? what not to touch?
i use engine degreeser. any brand will do.
b4 spray... make sure ur engine is cold. dun do it during ur engine is hot.. bad for ur engine.
wrap all the sensitive part of ur engine with plastic begs.
- distributor
- ecu
- open pod filter ( u dun wan kena water on this)
- any other things that is sensitive to water... (common sense la)
spray to those parts with lots of greese dirts. try to avoid spraying degreeser on rubber material.. like the belts.
leave for about 5-10 minutes.. rinse wif water.. spray water when needed only on those hard thick dirts.
there u go.. a clean engine :D
