[WTS] Hks super racing 10w35 100% synthetic oil
- 100% Brand New Original
- From Japan
- 4 Litres
- Applicable for stock specified #w30 Grade
- Max. Oil Temp. 130c
- 100% SYNTHETIC
- SM-CF Equivalent
- RM155
Description:
HKS engine oils are developed with an idea of that oil is a tuning part to maximize performance of engine. The unique viscosity categorization will effect at molecular level on boundary lubrication. Optimized oil viscosity selection solves
hydrodynamic lubrication. Airtightness and friction are highly balanced.
Engine building specialist at HKS now offer 100% synthetic special blend oil.
Benefits of using HKS Engine Oil - 100% Synthetic Oil High Shear Stability
1. Able to penetrate piston oil line during engine operation to reduce friction thus allowing smooth engine movement.
2. Seal up the gas leakage from combustion chamber to maintain good compression.
3. Complete absorption and dissipation to cool the engine and prevent it from overheating.
4. To eliminate combustion gas Unburned deposit that may affect the engine performance.
5. Remove moisture content from during combustion that create rust and corrode the engine.
SUPER RACING 10W35 is Recommended for Stock Engines - Lightly & Modified Tuning in N/A & Turbo Applications. With a good Cold Weight of 10w this gives ample protection for NZ Climate & thick enough to withstand moderate Fuel Dilation, 35 Hot weight running at Average Oil temp of 90c becomes a 40 Weight.
** Full Address Of Shop As Below **
** E3 Racing
** No.73A, Jalan 2, Pandan Indah Industrial Park, 56000 KL.
** Business Hour: Mon-Sat 10.00AM - 7.00PM
** Google Maps Search: "E3 Racing"
** Welcome Salesman, Dealer, Online Business Or Walk-In To Our Shop For More Products.
For more performance part inquiries, feel free pls contact/SMS/Whatsapp/WeChat@ below:-
- 018-227 5515 / 012 340 2733(Call Only)
Thanks & Visit Again...
- From Japan
- 4 Litres
- 100% SYNTHETIC
- SM-CF Equivalent
- RM155
Description:
** E3 Racing
