high cam setting
zulfadly
136
anyone can tell me how to set cam n campulley..
set btul..
bkn main ketuk2..
:biggrin:
jinkl
4,624
376
3,183
set btul..
bkn main ketuk2..
:biggrin:
1. U need to know how a head fully functions , lifters , valves , etc etc
2. U need the tools , do u have a cam dial gauge ?
3. U need a degree wheel
4. U need a need to know engine basics , TDC , BTDC .....etc
5. U need adjustable cam pulleys
6. If you are running on hydraulic tapets , u need to modify one to be made solid
7. If you dont at all understand wht i stated above :D hehehe alot more need to learn
*I ownself do not know how to do cam degree, i only watch the sifu's do it, and I can say is that I understand, but I do not wht so ever have practical knowledge of these, hehehe
first things first, you need a cam card , nearly all cams are not drop in cams, tht includes HKS , BC , JUN , FP , TOMEI , etc etc
this is how a cam card looks like , the below is for a evo8 cosworth cam
with the tools above stated , you will be able to degree/dial in your cams in a SERIOUS way that you have requested :D , no ketuk ketuk please
some pictures of cam dialing in process
Bump: please play safe hehehe , dont adjust wrongly, you could end up putting a valve into your piston :P
some more tweaking can be done after you have dialed them properly
Advancing Intake and Exhaust : This will provide the car with more bottom end power, and will decrease top end. Advancing both cam gears will move overlap earlier but will not increase it.
Retarding Intake and Exhaust : This will increase the cars top end, but will decrease low end. Retarding both cam gears will move the overlap later and but will not change the amount of overlap.
Advance Exhaust Only : This will help the cars top end, and it reduces overlap.
Retard Exhaust only : This will help the cars mid range power, very useful for cars with big turbos / big cams. By increasing overlap, It decreases lag significantly. Doing this will bring the boost on all at once. Very common DSM modification.
Advance Intake only : This will increase overlap and helps the cars bottom end and mid range power. This mod will bring the turbo on all at once, although isnt a very common mod for DSMS.
Bump: source : dsm boyz
zulfadly
136
tq very much jin kl..
ur information very clearly n berharga..
nnt kt blh kongsi2 pndapt lg..
blh ke jin kl?
:adore:
but where to buy a dial gauge?
it is put at crankpully isn't it?
in picture white color rite?
HaxDuum
142
which shop offer such details workmanship, nonono should call it "art touch-up"^^
actuator_bypass
57
Basic adjusting, make sure your position of crankshaft is at Top Dead Center on the first piston.. but this is ketuk, ketuk tuning with aerospeed adjustable campulley. To be precise or just to get clearance of 0.001mm TDC then you have to use dial gauge as what JINKL as state up there.
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
Really nice info Jin.:adore:
szeeonn
131
10
How if i ADVANCE intake and RETARD Exhaust ? would increase low mid power and Faster response for BIG TURBO ENGINE ?
tq
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
anyone can recommended me for do cam degree ?? i was tired ketuk2 cannot find the best proper tune help me :adore::adore::adore:
after ketuk2 u need to dyno and retune to fully utilize...
if just ketuk2 no retune also no point in doing it
Dear All, I've copied the name list for mini owners from ZTH Mini Club. Please help us to update the name list below. Sorry for all otais' if your name not appear here. Kindly help us to update. Cheers
1. skyline86-BAF1594, PS7102-subang-0124932832
2. khoyos-WB927-shah alam-0123200673
3. iwan_mini - BAK8216 (under construction) - Ulu Kelang - 0126985007
4. turbokidz - thinking to buy one - Sunway - 012 6333 733
5. feezdya - BR4242 - Kota damansara - 0126250002
6.
Thank you for...
