Nowadays Mugen is a bit blingin' lah. Spoon and J's Racing also got some bling, but more performance parts, like the bumpsteer kit, and all those chassis parts for S2K. Extractor - wise, I'd say Toda lah.
Engine mounts, yeah, aftermarket ones do not have gaps, and is made form stronger rubber. I'd like Hasport as well, but the obvious colour is a dead giveaway.....
- JPJ officer at roadblock : Bukak enjin.
- Me : Ok ( thinking since my engine looks stock other than the 5 Chicken extractor )..
- JPJ officer at roadblock : Apsal mounting enjin kau ni kaler2? Dah, amik surat ni. Lagi dua minggi pi JPJ, semua nk standard!
- Me : ........
Yeah, what you heard about P/U mounts is the same thing I hear as well. The P/U mounts must come with the correct grease ( usually it's produced by the same company ) and all the P/U parts must be greased properly. I think that's SuperPro's advantage lah, their P/U stuffs got grooves to put and keep the grease inside et cetera. But most importantly is who's doing the install also. Fella doesn't know what the heck the greas eis for, and simply lug in the P/U bushes like OEM rubber, thinking that these P/U stuffs is like OEM. Months later....aiyak! There goes my lower arm P/U bush! Kainenai....
shiroitenshi said:
Well.. I'd agree with ace.. Mugen is WAY more expensive than superpro.. and both WILL REQUIRE changing if used constantly for track use/aggresive use..
I like mugen.. but some of the parts are a bit too stupidly designed to deserve the credit like they get... e.g. Mugen valve cover.. What? No plug covers? and the cost.. sheesh!
Mugen makes nice wheels, nice interior accessories.. and the strut bar (I like the old one that bolts on the shock (syiok?) towers as well, but that' kinda rare now.) but performance wise.. I think they're a bit overpriced for the things you get. Extractor wise.. well.. they can't be beat because they make SO MANY extractors for various honda makes.. just flip tru a mugen catalogue and you can see how specific they make their extractors. EK/EG has different part numbers.. (O_o)
Unless you want to go full Mugen for bragging rights... I think buy whatever that gives the most BANG for BUCK. (or Malaysian style... more syiok for less ringgits.)
As for the rubber mounts by MUGEN.. well.. I've only seen Spoon's one.. and the most obvious difference I see is that they have no gaps in the rubber like the stock units i.e. solid rubber on the engine mounts.. the ori one has some holes for more cushion. I think mugen makes it similar as well.. solid rubber = more solid mounts.
Ace,From what I've heard about urethane mounts.. they depend a lot on the grease that came with the package.. if not applied properly the first time around.. the urethane dries out, gets brittle and comes off in bits, or binds like you said.
