Help me with my fuel system
hardcorecar
77
Sabah
hallo guys...do you ever had this fuel pressure not consistent issues??this is my story...i set my fuel regulator at 3.8bar then i drove my car for like several KM and then i open up my hood and my fuel pressure is at 4.0bar or more sometimes it could be 3.3bar and less..i run on stock fuel pump and injectors...soo what could be the error here???:hmmmm::hmmmm::hmmmm:
ken yeang
6,617
1,327
Try substitute with another regulator and see if the prob persists...
egb18c
922
94
kuantan
last time i had the same problem, the culprit was the gauge itself.
the location of the FPR was too hot,so i relocate the FPR and a good member of this forum gave me an idea to drain all the oil inside the gauge.now my reading is consistent.
l2s_turbo
1,068
154
Check your vacuum hose and vacuum source too..
Speeder
366
Leaking:-
Check vacuum hose
Check fuel hose
Devise problem:-
Change another gauge and test
Change another AFPR and test
Question:-
1) What type (either original or imitation) AFPR using?
2) Are you install it correctly? Possible share some photo to us?
hardcorecar
77
Sabah
Leaking:-
Check vacuum hose
Check fuel hose
Devise problem:-
Question:-
I'm using FSE MALPASSI adjustable fuel regulator..it has double diagfram which I think heavy duty right..
---------- Post added at 11:12 AM ---------- 6 hour anti-bump limit - Previous post was at 11:11 AM ----------
if cannot find the problem after troubleshoot... try check the fuel hose at the fuel pump....
got problem to start the engine?
Got no problem to start da engine..
HYE CFU'S OUT THERE...help me wit dis..im a studnt n want 2 save my bujet on dis.
ive buy a pair of subaru seats with railings..how to modified to fit in wira?
i hope cfu's can help me..
help me dunt let me down....hehehehe
