jep3003 said:hey bros,
i really need help, im driving a civic sohc turbo n everytime i boost, checklite on... Its da MAP sensor voltage 2 high because of da boost.... How can i eliminate dis problem??? im using an emanage...
Joeker said:I think 1 bar map sensor can't use on Force induction.
You at least need to start at 3 bar map sensor.
jep3003 said:cipan,
better 2 use check valve or boost cut device??? wat r da pros n cons of both??? but i wud still be able 2 tune my emanage rite???
ecupro said:J101,
1 bar map sensor only for NA application.
So, joeker is right. At least, you need 2 bar map sensor for 0.0 to 1.0 bar boost.
2.5 bar map sensor will be 0.0 to 1.5 bar boost.
For Haltech 3 bar map sensor, it will be 0.0 to 2.0 bar boost.
Similar threads | |
