HELP!!! Kelisa can't start!!
lek9925
37
i had changed the map sensor, cam shaft sensor and swapped ECU, but the car still unable to start.
Any professional is available to help?
will the alarm system cut off the ignition coil? no spark while engine is cranking!
Please kindly advice and your help is greatly appreciated!
leynye yamin
106
22
518
Sabah Sandakan
is your car alarm is factory ones? if yes then try reset the alarm, which is put the key into the ignition, turn to on, press the alarm remote, and while holding on to the button you turn the key to off and back to on continouosly for 4 times, the car should beep on the alarm and your car should can start. good luck!
I have been told that Rain-X affect the durability of the glass that it is applied on - changes the molecular structure and makes it more brittle .Something to do with the surface tension apparently ?
My friend has experienced it before when his windscreen suddenly cracked for no reason. That stopped me from trying Rain-X out
It was parked under his proch and he suddenly heard a crack ( new car ) .Nothing could have fallen on it as it was under the porch, and it was a normal sunny day...
