help:about apexi safc 2 blue screen
nukemocca
11
need help about setting up my safc2..
engine:4g92p (sohc) stock punye..geee(wira 1.6 xli)
i try to setup my safc by change the correction value at lo,hi trottle..
but nothing change at engine pefomence..i really2 dont feel anything..
(da bace manual semua da)
but at 1000 rpm(static car)..i do hear the diffrent went i change the value..
someone..help me.
BananaBoyz
217
hi 20% low 10% throttle... you must have afr meter to change the value...
lean to rich
nukemocca
11
im already set my throttle lo 10% and hi 40%..
i dont understand to setting up the Air correction factor setting (Throttle opening, large / small) do i need afr meter to change the value?
the manual wrote that the correction factor is +10%, the ECU recognizes that
the air volume has increased 10%, so fuel is increased about +10%
i try increase the correction value to 15% at 4000-6000 rpm.. but still fill the same..my car still slow..
but i can hear the diffrent at sound of engine went i change the correction value at 1000rpm(stop car).. am i missing someting? or just my engine already rich the limit? coz all part in my engine still stock
Northiswara
2,589
7
try -10% then u might see power!. running too rich wont give u power. as i heard, below 3k rpm u can try set to -5 to -15% but depends on engine and modification. watch out for pinging.
nukemocca
11
tq so much...
and about the sensor type..
wat type i have to use? :hot-wire,flap,pressure,or karmen?
again,my car is wira 1.6xli soch..no bot..stock only..
and
wat the maximum correction value i can rich? from 4000rpm to 6400 rpm?
fct
211
kluang,jb,spore
someone..help me.
u must get ur initial setting right.
4 cyl,throttle up,sensor =karman ,in=? out =?(must be same follow manual)
and from there set ur throttle low and high %,normally low 20 high 50
it depend on ur throttle sensor and driving style.
and last set the +-%
Trinityblood
3,371
21
waah very good bro learn you self,can save $$$..hehe
pioneer411
Bro, My friend got SAFC2 on his Evo 7 GTA, he say after pasang SAFC2 macam nth different in perfomance.. maybe he dunno the setting, and at our town, macam tiada ppl know set and dont even think have a dyno machine,,, hope to know some sifu here, teach me how to use the SAFC2, then i tell my friend.. his car all stock, evo 7 auto, with hks suction kit only
BananaBoyz
217
just rev then base on afr...dyno tune suck..i only go to dyno just to know my hp and tq
renxun
1,138
37
get some friends together. gather some money to get a good wide band sensor.... then do some read up in the internet to get a rough idea on what kind of air fuel ratio u should run and start from there
nukemocca
11
im using 4g92 wira stock.. i change my sensor type to karmen..but it not effec at all.. i change my correction value at 1000 rpm..nothing change..but went i change my sensor type to hot-wire or flap..baru bole... why aa bro?..wrong connection to ecu? :stupid:
Meet the Jaguar F-Pace. A new contender and yet another contributing proof, indicating the immense market needs for more SUVs. Nevertheless, the F-Pace combines what’s good from Jaguar and the key features wanted in the market nowadays.
Sitting in the same league as the Porsche Macan, Audi Q5 and Mercedes GLC, the Jaguar F-Pace boasts a sleeker design; taking cues from its full-size sedan sibling, the XJ...
