no need to change ecu, use management
TD025 many 4G15 bot user use TD04
Zerotohundred.com > Technical Section > Tech: Forced Induction > turboe'd 4G15
found this mod from serbia
4G15 12v sohc '92
1.intercoler & pipes 700x350x100mm
2.turbo IHI VL7 max boost 1.4 bar
3.injectors 450cc
4.fuel preasure regulator @ 4 bar
5.custom mainfold and downpipe
6.stage 2 clouch set custom 150 whp+
7.platinum sparks
8.boost gauge
9.air/fuel ratio gauge
10. new O2 senzor-lambda
11.new fuel pump
12.Apexi safc 2 piggyback for ecu managment
13.blow off valve
i run my laner @ 1 bar - 14 psi about 2 years with modifications & i havnt problem with cooking.
Stock head gasket,pistons,ECU-ECM & 185whp 136KW
**I rise the turbo preasure on 1.5bar with manual boost controler and then KABOM big white cloud under the hood, 2 years on 1 bar and 3 days on 1.5 bar. lol**
