helicopter rotating noise
Supachip
205
puucuung
3 weeks ago, while on the way to wangsa maju, the front undercarriage part of the car suddenly appeared to produce "kruk kruk kruk" noise at 60-70km with foot on throttle.
Once throttle was lifter, noise will gone.
Went back home, lifted the car to check for free play on both front wheel bearings. Apparently, no freeplay at all.
Went to workshop, swapped 2 driveshaft, pumped in a new RHS wheel bearing. Changed left and right engine mounting but problem still persisted.....
Definitely not piston knocking noise as there's no engine oil consumption and sparkplugs are clean, vehicle drives fine.
Exhaust piping also checked.
Everytime when the engine is under loading, e.g. slight slope, speed 60-70km/h, the "kruk kruk kruk" helicopter noise will appear.
I've checked with my friends (very experience technicians) but no one can tell where the noise is.
By the way, my car is stock 1.5 engine, 16" rim, lowered.
I really out of idea already.
Any pro pro pro sifu here can help me?
DarkAccoon
880
432
3,063
this may not be relevant,
but check the mudguard under ur car
maybe loose
cause last time my brother's car also showing same symptom
so when he goes around 80, the plastic piece flew towards the tyre and make the exact same type of sound
once above that speed or when he let's go of the pedal, the sound disappears
Supachip
205
puucuung
satria_95 said:
Supachip,
Does your car vibrate when you step on the accelerator?
Yes, indeed, when step on the throttle pedal, I can feel like metal parts are knocking/rotating.
Definitely not the mudguard, I've checked.
I start to suspect that problem might be coming from the differential gears......
Last night while i was driving in Shah Alam, there is an illegal race of some sort.
There is matte black cefiro (with BOT coz can see intercooler) and a white Nissan 350Z.
But how come the 350Z lost? If cefiro is stock rb25det can challenge a stock 350z without modification?
