Headlights having a mind of its own..
holysniper
159
518
N/A
I am still on halogen lightbulbs. Sometimes my driver's side headlight occasionally goes dead, but comes alive the next day or after.
Just suddenly ytd night, both went dead. So I was like :confused::confused: okay then i jus drove with foglights. Just now I went to check again, found out that my driver's side have light, the passenger's side dead. :banghead::banghead:
Anyone had this problem before or have some advices? Thanks!:confused:
holysniper
159
518
N/A
probably the connector is loosed.. my friend had the same problem..
hope is jus the connector loose.. next week den go workshop.
anyone know can I get only 1 side of the headlight assy anywhere? I need the driver's side.
reefdee
97
5
1,508
Putrajaya
try searching on mudah.. last time saw a guy selling a new one for rm180 a side.. thats the cheapest i ever saw.. if you go proton parts its over rm300 per side! :mad:
reefdee
97
5
1,508
Putrajaya
hid more stabler cos they got their own balast.. i'm using it as my main low light.. almost a year now... no issues with the hid kit..
nadziad
287
28
528
johor
sometimes u need to relocated the ballast......hid it where water cant pass....mine also had the same problems
holysniper
159
518
N/A
Oh.. probably going to install his saturday :)
How much does a set of Taiwan hid with 1yr warranty cost?
hamtaro00
279
39
528
Ipoh
hi, ballast might got prob, but 1st check ur connector and those cable 1st. mine same case, since connector is cheaper, i checked it 1st and voila!
First of all, thank you for coming in.
Please share;
1) What spark plug brand you are using?
2) What is the code?
3) Fuel pressure?
4) Injectors?
5) Fuel pump?
6) Boost pressure?
Today, i downgraded from Denso Iridium IK24~heat 8 to NGK BKR6E-11~heat 6 (standard)~ I am so affraid to boost although with standard pressure~ :adore: Consider everything stock standard~ I'll post pictures of the new spark plug installed after a few runs soon~ :bawling:
Please help~ :bawling:
