Head valve cover nut oily/greasy
ddv_nk12
1,228
236
663
PD
As mentioned in the title, what is the cause and what am I looking at to replace/repair?
Please check out the attachment for reference. The nut which is circled in white is the problem.
g4i8y0t
1,216
330
683
Kedah
I faced this problem a few months ago. Now solved already. I think mine was more severe, all 5 head cover nuts were covered in oil (my engine is a weak D16Y7 non-vtec :biggrin: ). The problem with most honda head cover is that the thread in the head itself is not through-hole type. Meaning that, if the seal under the nut is weak already, no matter how tight you torque the nut it will still be covered in oil. The solution: replace all the seal and put some new head cover gasket for good measure.
ddv_nk12
1,228
236
663
PD
Got it. Thanks mate. I noticed that this particular nut, can't be tightened. It turns and turns but doesn't tighten. Why ah?
me2kimi
717
276
1,563
Puchong
IMO it can be source easily at spare part shop.
ddv_nk12
1,228
236
663
PD
Do you mean the nut?
AD_EG
6,328
231
Ipoh
either the nut needs to replaced or the thread worn out cause over tighten.
ddv_nk12
1,228
236
663
PD
If thread worn out, is there any solution?? I just tried using the other nuts for this corner but it's still the same.
g4i8y0t
1,216
330
683
Kedah
Maybe the thread loose already? If it is, go find workshop that has tap & die set, the thread can be re-threaded. You'll have to use slightly larger nut after that.
ddv_nk12
1,228
236
663
PD
Aih, if thread worn out, nothing can be done right?
AD_EG
6,328
231
Ipoh
should be able to re-thread
ddv_nk12
1,228
236
663
PD
Bro, mind to tell where? Machine shop? Lol.. Me very :stupid:
l2s_turbo
1,068
154
Where r u now bro? JB or KL?
ddv_nk12
1,228
236
663
PD
JB...........
l2s_turbo
1,068
154
Pm me ur contact.. i tell you where to go to..
ddv_nk12
1,228
236
663
PD
PM'ed. Thanks bro.
Good morning everyone, hope everyone is doing well in this pandemic and abiding SOP at all times.
Came across an aftermarket brake kit brand in Mudah and was wondering if anyone can vouch for this brand? The price also seems reasonable in my book considering what is being offered in the ad, but who knows I might be wrong.
Here is the link to the ad: Iswara Saga 1.3 1.5 RSS...
