hi .... i just find out that gtti n hd have the same size of piston....76 mm...
so anyone out there had try to install Gtti piston inside hd block for turbo charge...
does anyone out there compare the piston..
i wanna find out ... does the shaft n pin Gtti piston is at the same location as the hd piston...
the lenght from the top piston to the shaft hole.?..
the diameter of the shaft hole ?
any one out there that can share the info..plsss.....:Not_Impressed:
