Dear ZTH members,
I would like to introduce this made in Malaysia products which have been in Europe (Bio Dutch) and Japan (Eco Booster) for more than 2 years and now available in Malaysia. Please contact me at +60199515188 or email at [email protected] for further informations.
GREAT BIO-FUEL Enhancer is an unique "state-of-the-art" biotechnology breakthrough product of the millennium. Fuel in any engine does not burn completely and gets worse as the engine gets older. The inefficient unburned fuel becomes dangerous exhaust emission then pollutes the environment. The exhausted gas also creates carbon build up in engines and robs it of its power and performance.
When the GREAT BIO-FUEL Enhancer is added into the fuel, it will immediately breakup the chains of hydrogen and fuel molecules into properly arranged atoms through a process of ionized molecular restructuring. It exposes the fuel atoms to more oxygen and creates a balanced burning and is able to increase the level of combustion of up to 98%, thus giving the engine more energy and power.
The GREAT BIO-FUEL Enhancer will also lubricates the Combustion Chamber and gives the pistons a smoother rotational motion. Fuel mixture is burnt with minimal fuel residue. Clean residue is expelled out through the exhaust. Carbon deposits on the Chamber walls, piston rings, plug head, intake walls and injectors are slowly removed and expelled through the exhaust. Less wastage and more efficient burning results in reduced fuel consumption which is translated into better mileage for every tank. Instead of being expelled in the form of toxic emissions, unused fuel is now saved in the tank waiting to be used efficiently by the engine.
The GREAT BIO-FUEL Enhancer will perform the following functions:
1. Naturally lubricate the inside of the engine to increase it's life span and reducewear-and-tear.
2. Give a fuel savings of up to 15% to 25% by reformulating the fuel.
3. Reduce the toxic smoke emissions.
4. Remove Carbon deposits on chamber walls, piston rings, injectors etc.
5. Dissolve water vapor which dampens the Chambers.
6. Deliver extra engine power and performance.
7. Ensure added protection to the fuel delivery system.
