Goodyear launches Asymmetric 6
The New F1A6 are 7% better in Wet Braking, lower in Aquaplaning resistance but better in External noise.
From the photo comparison of the old F1A5 vs F1A6 the long Kang seems to be smaller, hence the lower Aquaplaning resistance.
So Guys, What do you prefer when choosing a new tyre? Other than Price of course.
Handling, Rolling / Aquaplaning Resistance, Wet or Dry Braking, External Noise, Wear Rate?
I'm more into a better Wet Braking and Aquaplaning resistance.
Which of the two are more suitable/important for our daily road uses?
That is exactly what most will ask, not only between old and new model, but between different categories, like UHP, UUHP, Extreme, Semi Slick. For you looks like UUHP is the max, once into extreme, usually wet handling suffers
6UE5t
6,000 RPM
6,756
1,300
Dry handling, dry/wet braking, and aquaplanning resistance.
hello,
i got dificulties in fixing this, this is water system for 4age engine..
how to fixed this upper mount ( which is connected to the upper hose on the radiator) to the lower mount ( connected to the water pump ). I try to fixed this but since it a bit rusty , water still came out no matter what..
i try using o-ring but no avail..then i use this special glue i bought from shop to hold them but still once i start to put in water, still the water came out..
hopely anyone can...
