100% Brand NEW in BOX
- Price for 2pcs (1pair)
- Fit To Nissan S13,S14,S15,240sx
- Installation can be arranged.
- Price excluding GST 6%.
-GODSPEED NISSAN 240SX S13 S14 89-98 (S15 ALSO) MASSIVE ANGLE KIT
OEM knuckle GODSPEED knuckle leading wheel 38 degrees 56 degrees trailing wheel 30 degrees 46 degrees turning circle (curb-to-curb) 30.1 feet 23 feet lock-to-lock 3 turns 2.6 turns
*note: for s13 240sx customer this must be use with a s14 240sx wheel hub.
GSP massive angle kit is a direct fit kit without modification to your stock oem knuckle piece. This massive angle kit is ONE PIECE MADE kit , unlike most kits out there that are cut and weld with the oem steering knuckle, and not to mention NO NEED FOR CORE EXCHANGE. This is made by oem manufacturer with oem quality material. GSP massive angel kit will give you more extreme angle on your S13 / S14/ S15 without modifying the front lower control arm. The Massive angle steering kit will stop at exactly 55 degree , if you modify the lower control arm bump stop this angle kit will give you additional 5 to 10 more degree (depending on how you modified your bump stop)
OEM knuckle vs. Godspeed Knuckle
-Leading wheel: OEM is 38 degrees vs. Godspeed is 56 degrees
-Trailing wheel: OEM is 30 degrees vs. Godspeed is 46 degrees
-Turning circle (curb-to-curb): OEM is 30.1 feet vs. Godspeed is 23 feet
-Lock-to-Lock: OEM is 3 turns vs. Godspeed is 2.6 turns
Location : 22M,1st Floor, Jalan Pandan Indah 1/23A, 55100, Pandan Indah,KL (Look for Sign Board JASMA, above Trinity Pharmacy).
Payment option:
- Online Payment/Postage:
Payment option:
GODSPEED NISSAN 240SX S13 S14 89-98 (S15 ALSO) MASSIVE ANGLE KIT model 31484 (13).JPG101.5 KB · Views: 125
GODSPEED NISSAN 240SX S13 S14 89-98 (S15 ALSO) MASSIVE ANGLE KIT model 31484 (12).JPG112 KB · Views: 69
GODSPEED NISSAN 240SX S13 S14 89-98 (S15 ALSO) MASSIVE ANGLE KIT model 31484 (8).jpg36 KB · Views: 68
GODSPEED NISSAN 240SX S13 S14 89-98 (S15 ALSO) MASSIVE ANGLE KIT model 31484 (8).jpg36 KB · Views: 70
