Getting a 2nd hand Mazda RX-7 1996
pwhyze
924
356
1,563
If its sequential, can't one use a big turbine turbo for high RPMs and a small turbine turbo for low RPMs?
Also, I still don't understand why people say plugging a turbo into a car is gonna ruin the car. Its just recycling the combusted air that comes from the engine before exiting the car? If there were to be any damage it would probably be the back pressure from the turbo and it that case wouldn't the engine just stall?
What you've described is essentially a sequential turbo setup, which is what the RX7 came with originally...:confused:
'Back pressure' or turbo surge would cause compressor stall, which could result in possible damage to the turbocharger unit. Easily solved by using blow-off valve/ anti-surge valve.
When people say 'ruin' the car, I think what they mean is if the car is originally NA, turbocharging it would alter the 'character' of the car. I don't think they mean it in a literal sense.
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
CSA, please do read all the sticky in the RE club. Guys like Phat7 are season owners of Rotary and there's a reason why they go single turbo instead of the twin setup.
I've took a look at the mod list the link you posted and I'm pretty sure the owner knows his stuff about the car and I won't go simply changing the stuff that he had put into the car and end up messing it up and then regret after that. If you really bought the car I suggest you just drive the car 1st instead of thinking to mod this and that. Get used to the car 1st and feel how the car behave.
Clutch_Shift_Accelerate
81
17
508
Well of course i'm going to test the car and run around in it for sometime. I'm only putting that mod list there to get opinions + I only plan on doing it if the car really needs it. My first priority is to get the basic things running like installing a v-mount, etc..
I'm going to change my wira 1.3 door panel to lancer door panel which use power window button at door trim...What i realized is power window motor only use 2 wire but at door trim switch got more than 2 wire...What i want to know is what is the function of other wire...is it need to add up relay??
