Front door light need help
HL Milk
47
B'worth
hi all DIY sifu here, i wanna install a DIY door light (those like the BMW or Mercedes con. car). When the door open the light on. Need some help for my door light wiring. i got few question here. hope can get the solution.
1. Which signal point i need to take? Where is the door open sensor?
2. If the door open sensor is not at the door then the wire have to travel from door to interior. So how to hide all the wire?
3. I need to make a hole for the light mounting on the plastic door. So when i'm sound proof it all the wire and the mounting will covered. so any solution?
Please advise.
thanks.
azamprocc39
102
i want tr also..... can i use the door switch(when door open, interior lamp on) or need tu put new switch to make the new door lamp work?(like waja laa)
jaywat
1,329
If the lights at those 4 doors is trigger by the switch then all door light will light up when 1 door is opened...must think of other way.
masvidal
253
Kota Kinabalu
what switch lah bro? i think no need switch. might just tap the wire from the interior roof lamp (because u can set the mod there, when open door, the roof light on).
but how to hide all those wire. might need to open all the interior roof.....sigh.....
Maxx
2,072
42
PD-Putrajaya-KL
www.zerotohundred.com
can use the existing door switch.
if dont want other door light to lit, can use diodes.
im using diodes for rear bonet lamp so it will not lit if open other doors or frnt hood.
BlackMafia
78
i'm not sure that it need any relay or not ... but for sure ... u can get + wire from ur alarm control box ... ... if i not mistaken ... the colour is orange ...
and then the ground ... biasa laa ... skrew at the body ...
HL Milk
47
B'worth
I'm still blur blur leh. all brother if can please put some picture to show mah. picture worth more than thousand words leh. For me i not very familiar with the car interior wiring. I'm already got some ideal for the lamp at the door by using LED but the problem is where to take the point (when one door open only that particular light is on, not all on). The other one is how to hide those wiring. Can we take the door close signal that on the door panel?
BlackMafia
78
ermm ... put some pic ?? sorry i'm so good for draw ...
if like this ... i guess senang lol ...
ok .. ok ... i here to help ...
ok what was i know the door sensor wire is - ... so ... ur led wiring will be like this ...
the + just join it direcly from + batt.
the - just join it from door sensor wire.
example ... when the driver side door open ... the led on driver side only be menyala ...
Maxx
2,072
42
PD-Putrajaya-KL
hmm.. ill try draw the diagram.. but wait 1st have to search for diagram drawing software..
lazy to use paint, etc.. hehe.. :p
Maxx
2,072
42
PD-Putrajaya-KL
hmm.. cant find any diagram s/ware..
here.. hope it helps..
shown one door only.this is the basic door switch use in cars. u have to cut the existing door wire and put diode there and do the lamp wiring as shown. pls observe the diode polarity.
kruger
521
A.Setar
hmmm... this one also could work....
wei khguan and votech... revise the circuit please... :)
khguan
4,818
26
Seri Kembangan
fotopic.net
hmm.. de door switch wire is +ve?? i also not sure leh.... i need to test with a bulb 1st.. gimme some time.. bz lately...
i also got think wanto do dat light... wanto get those fender signal lights then korek a hole at de door then mount it..
y use a diode?
HL Milk
47
B'worth
But the existing door switch is at the car interior (not at the door itself). So how to hide the wire (connect from the lamp to the switch).
got another ideal here. but i think not to practical.
1. using the power window to light the lamp.
2. adding a switch and a relay inside the door.
3. mount the switch at the door opener (inside). when we pull the handle the switch will open to trigger the relay to on the lamp. but when we open from outside the car then the car will not on the lamp :D . But this will reduce the wiring a lot mah.
i got a lot of o*r*m LED for those who like to DIY for themself to become a full LED lightning :p . blue, white, red, watever colour lah. And if using LED its really save up the power that consume from your baterry and not heat from the LED itself and long lifespan for LED :eek: . As for the result from the founder of LED, if proper use the LED those LED can light up for 3 and more year without off it :eek: . So imagine that your daily using car. maybe your engine kong then the light will on loh :D wahahahaha........
HL Milk
47
B'worth
Why i wanna LED for whole light of my car? cause i really fed up with those bulb type that always blow one. recently i have change 3 bumber bulb for wira RM9.50 X1, 1 set of small light (no plate one) RM15. cause this few week always raining, always saw some tinny water inside the bumber light and also the headlamp. So maybe after changing to LED will save a lot and get longer lifespan.
I founf one japanese webpage that show how to DIY a LED lamp and the layout. But too bad i cann get the reflector for it. anyone can help? if not i will make the trasparent plastic and stick with aluminium foil liao :D . wahahahaha......... but is difficult to find the round type plastic cover. hai..........
Maxx
2,072
42
PD-Putrajaya-KL
huh..what bulb u changed? the normal bulb or halogen? kinda expensive.. normal bulb only cost 0.60->2.00.
