what is the usage of changing to a lighter flywheel?
it will bring more power??
tq
kam sia...
tq
kam sia...
not bad bro u know some stuff ;)jee_square said:Lighter flywheell means greater torque means better acceleration.. Throttle response is also good but ur top speed is sacrificed a little bit.. Lightening ur standard flywheel is not recommended coz some people say iy might give it a crack.
aftermarket lighten flywheels are 'lighter' due to different material composite and NOT by 'local' skimming.Yong_5290 said:lighter flywheel has more torque???tats funny...lighter flywheel will lose its torque due 2 the momentum...
lightening std flywheel not recon? well...depends how much u wanna skim...
y ppl upgrade 2 1.6/1.8 super toruing flywheel?
tats bcoz theres no racing clutch set 4 stock 1.3/1.5 flywheel size...
koolspyda said:aftermarket lighten flywheels are 'lighter' due to different material composite and NOT by 'local' skimming.
That is a low-tech way of doing things (exactly like cutting springs to lower the car so you look cool)
BY skimming the surface area YOU are reducing the thickness of the flywheel in the hope of reducing weight.
THAT is a compromise way to improve !!! Hence the silliness of complains that one will lose torque esp going up hilll! :cool:
Note the difference! It s almost like saying cutting springs will help in body roll as the car sits lower :rolleyes:
BTW aftermarket lighter flywheels DO NOT / IS NOT done by skimming it.
Please do not confuse with with the el-cheap way to do things.
THe danger of skimming flywheels is if it done too much, when enourmous pressure is applied to it (shifting gears) , it will CAUSE BREAKAGE!!
IT is the same reason why rotors/brake disc if skimmed toooo much will crack.
YOU are only putting yourself in DANGER. think about it!!
Yong_5290 said:ahaha...u got me wrong...i was refering 2 ori stock flywheel being skim
it was refering to stock flywheels being skimmed to shaved metal bits to reduced weight. if low-tech way is the only way one to go because of $$$BTW aftermarket lighter flywheels DO NOT / IS NOT done by skimming it.
