Ferrari F430 Interior Makeover @ the detailien HIVE
seech
400
445
1,563
This lovely yellow prancing horse dropped by the detailien HIVE for some much needed attention to its interior.
Things looking good on the outside.
But another story on the inside where all of the soft touch coatings have started to degrade, melt and is sticky to the touch. Especially so in our hot, humid Malaysian weather.
Can anything be done or will the owner have to spend thousands for it to be replaced or resprayed.
Lovely interior....
Spoiled by the soft touch coatings on the plastic bits.
After some detailien magic with the help of Optimum Power Clean:
Before:
After:
Looking much better.
Before:
After:
Thanks for looking.
More to come.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
that's some awesome work seech
I'm intrigued by the soft-touch cot fix, how does the Optimum Power Clean work to resurface the soft-touch layer?
It looks brand new after treatment surprisingly, especially when looking at the scratches and indents from the before photos
esthapo
Trail Bomber
796
186
1,543
Sister'sBedroom
Marvelous work done seech!
Bimmer common issues eh Tom? heheheh I was also going to ask the same question to seech
seech
400
445
1,563
Hi Tom. Thank.
The OPC just removes the layer leaving the underlying plastic behind. There is no real way to replace the soft-touch coating as it has degraded over time in our weather. So unless you want to replace the parts with new ones, which would probably only last a few years, this would be the best option as it gets rid of that sticky mess leaving behind just the plastic.
The scratches were all on the soft-touch coating so once that was removed, problem solved.
Thanks. This is a common problem on most conti cars as their interior materials etc. were not designed for our heat and humidity.
Worked like magic!
Any detailing at the engine bay?
Yes. Car was fully detailed but didn't take any shots.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
Hi Tom. Thank.
I see, i never knew thats how it works. definitely beats replacement and to rid the panels of the soft touch rubber coat makes it a permanent solution. very nice.
Not really though, my old BM doesnt feature soft touch coatings, i believe most BMs of today are safe from that gooey mess. Although I suspect the newer MINIs may face such problems
esthapo
Trail Bomber
796
186
1,543
Sister'sBedroom
I see...I've got the problem mostly on my door handle & center console on my beemer which Goo Gone are currently the temporary solution :biggrin:
My old Sonata have a thin plastic coating on the window switch panel, so I use polish to polish until bare plastic so no more scratches also.....:driver:
seech
400
445
1,563
Polish would probably work also as it will remove the plastic coating as well.
Hi all zth member,
Would need all of your kind assistance give a look to my friend satria [ convert to Gti ] , just lost his car on 7 March 09 , time around 5pm - 11pm at Tmn Shamelin Perkasa .
Number Plate: - NAR 9413
Please drop me a sms or call if you notice a satria gti look like below:-
Number - 0126450339 - Isaac
- No front grill cause previously had get stolen
- The original satria 1.3 antenna ( on top of the front door )
- No any sticker
- Colour is skyblue...
