Evo2 pistons
Karapok11
45
Hi all,
may I find out the limits for the Evo2 pistons to withstand boost pressure?
Is 1.2 bar safe for evo 2?
Karapok11
45
I'm using HKS 264 cams, stock turbo, 3" pipings and emanage...
Can the stock evo2 pistons withstand 1.2 bar?
Lancerboy1
248
Boost
to be extra safe, i advise u to stop boosting ur EVO. =P
Karapok11
45
khoyos said:
evo pistons can withstand much more boost than that, but evo conrods cant
Yes, actually I've heard of this evo3 conrods 'crank-walking' which would effect the piston rings at higher boost due to vibration.
Can I have a more clearer explaination from your expertise on what exactly a 'weak' evo conrods meant? Is it due to 'crank walking' or its the material strength of the conrod itself?
Thanks in advance bro... Having said that, can I say 1.2 bar boost is still dangerous?
Karapok11
45
AfterMarkets said:
karapok11,
have ur engine got metal gasket...
if yes... 2bar also can bro
For mine, I've yet to change though.. But with the stock pistons, I'm sketical that it can withstand 2 bar...
So u running on 2 bar with stock pistons?
Karapok11
45
Hmmmm, haha, guess I should take out the turbo? So free ah,not doing your school work? dont come disturb my thread, :P
Mr. Saturn
14
its not a question of how much boost they can handle, rather it is how much your engine pings. they will survive a lot of boost if your engine doesnt ping. conrods might not though.
A Post Every 5 Mins
Hi guys.......need ur help a bit on where to find a 5 Speed gear box to be converted from a 4 Speed gear box? How much is da cost?
